Drilling Holes In A Glulam Beam? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 11-09-2012, 04:12 PM   #1
Drilling holes in a glulam beam?
I want to drill four small (7/32") pilot holes in a glulam beam to mount an exercise pull-up bar with 2" lag bolts. Is this OK? I'm guessing that I'm fine, but I know that there are very specific rules when messing with glulams carrying heavy loads.
The beam spans my three-car garage on a two story house. I haven't measured the beam, but it's probably about 7" x 15", there's a support post at 2/3rds the span.
Please let me know if this is okay or not? Thank you.
kevinf. is offline   Reply With Quote
Old 11-09-2012, 04:20 PM   #2
Rewards Points: 14,312
Should not be an issue.
http://www.rosboro.com/index.php?act...chnical.glulam
kevinf. (11-12-2012)
Old 11-09-2012, 07:46 PM   #3
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 1,354
im with joe. if you just want to drill into it to allow for mounting to it.. s houldnt be an issue.. now if your drilling large holes it would be a different story
woodworkbykirk is online now   Reply With Quote
The Following User Says Thank You to woodworkbykirk For This Useful Post:
Old 11-10-2012, 08:32 AM   #4
AHH, SPANS!!!
Rewards Points: 1,166
may nor even need to pre drill with these screws...
http://www.grkfasteners.com/index.php/en/
hand drive is offline   Reply With Quote
Old 11-10-2012, 08:39 AM   #5
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
Example of Hole Drilling Guideline: http://www.rosboro.com/index.php?act...chnical.glulam
- Build Well -
Core drilling multiple holes in concrete hartkem Concrete, Stone & Masonry 8 06-22-2012 11:29 AM
Drilling holes in meter pan OK? ScottR Electrical 11 05-13-2011 07:21 PM
Drilling Shelf Pin Holes in Existing Shelf Red Truck Carpentry 7 05-11-2010 09:27 AM
Drilling holes through studs paul_arc Electrical 17 05-20-2009 04:23 PM
Beam Replacement? Steve Dailey Carpentry 5 05-19-2008 08:46 PM
