Drilling Holes In Concrete - Building & Construction - DIY Chatroom Home Improvement Forum
Old 05-23-2011, 03:48 AM   #1
drilling holes in concrete
i would like to know if i can drill a hole around 70mm into the balcony so i can install some balisatrade post and then glaze them with glass and hand rail
Paul Bristow is offline   Reply With Quote
Old 05-23-2011, 03:57 AM   #2
Rewards Points: 95
If you have an SDS drill that is powerful enough and the right size
masonrydrill then yes you can.
However, the concrete in the balcony is not very strong and it relies on steel reinforcing bars to work as a balcony.
If you try to drill above or through a steel bar it will take forever and you will damage the integrity of the balcony.
You must position the holes so that they are inside the perimeter of the steel reinforcement, then the steel will provide the support.
Outside the steel perimeter the concrete may snap off sending you crashing to the ground outside.
Not good! Make sure you locate the steel reinforcement.
Perry525 is offline   Reply With Quote
The Following User Says Thank You to Perry525 For This Useful Post:
Willie T (05-24-2011)
Old 05-23-2011, 08:11 AM   #3
Rewards Points: 5,336
How thick is the concrete?
How high off the ground?
Ron
Old 05-23-2011, 06:57 PM   #4
Originally Posted by SharperCleaning View Post
Drilling a hole in concrete is a common activity for professional contractors as well as Do-It-Yourself and is one that needs to be done correctly and safely.
  • A hole needs to be drilled in a concrete, brick or block wall to create a pathway for pipe or wiring.
  • A hole needs to be drilled in order to install a concrete fastener or anchor.
I hope you like these suggestions. It will really help you.
Uh...this post makes no sense. Is there a link missing or something?
The OP is asking "How can I drill a hole" and your response is "Holes are drilled for pipes or anchors".
Vincer is offline   Reply With Quote
Old 05-23-2011, 09:46 PM   #5
There are many of these posts. Just thank them for their time and move on.
Ron
The Following User Says Thank You to Ron6519 For This Useful Post:
How To Install Rigid Foam Insulation on Concrete earthad1 Building & Construction 9 10-26-2010 09:49 AM
'hard patching' blast holes in concrete warehouse floor shag_carpet Flooring 0 09-08-2010 04:29 PM
Bad Concrete in Fence Post Holes - Advice? bcrenshaw Building & Construction 2 08-24-2008 11:21 AM
forming shallow holes in surface of wet concrete mx13 Building & Construction 1 04-25-2008 09:59 PM
forming holes in surface of wet concrete mx13 Landscaping & Lawn Care 1 04-25-2008 05:06 PM
