Drilling And Hanging On An Acrylic Splashback - Building & Construction - DIY Chatroom Home Improvement Forum
Old 05-17-2013, 01:42 PM   #1
Drilling and hanging on an acrylic splashback
Hi all,
I have an Acrylic splashback (not glass) which i want to drill into and fix a hanging rail to. The problem i have is that the splashback is fixed onto a plasterboard wall. I've been using the big plaster board wall plugs which have worked well.
Once i drill through the splashback, what type of plug should i use to help strengthen the join as i won't be able to screw the above type in? I dont want to drill the hole so big as to fit a wall anchor in? Any ideas? Thanks!!!
Also, drilling into an acrylic splashback. Sharp mutipurpose bit at a slow speed with water to cool?
charliem is offline   Reply With Quote
Old 05-17-2013, 03:54 PM   #2
Roofmaster
Rewards Points: 2,210
To me, a splashblock is what you put under a downspout. What is a splashblock to you?
Drilling vertically through structural beam? dyi_sometimes Building & Construction 15 11-01-2012 12:43 PM
Hanging shed door cmatychak Building & Construction 4 10-21-2012 08:49 AM
Hanging an overhead fixture jbcurrier Electrical 8 11-25-2010 11:19 AM
Drilling asbestos siding (hanging shutters) MichaelDutch Remodeling 3 06-15-2010 10:49 AM
