Drilled wrong spot in my door
Scorpio has it right.
There's not much you can do beyond that, outside of buying a new door. It sounds like you are painting the door (Hopefully).
You should do as Scorpio wrote. Use wood glue to re-install your cut out round (again, assuming you used a 'hole-saw').
If the 'round' is non-usable', cut out a new one from scrap wood and install.
As was cited already, you can use wood-epoxy or bondo. skim Coat the repaired area, let dry, & sand...then repeat, until it looks right. Then - recut your hole at the right location. (Yes, you can drill through the wood epoxy/bondo)
Good Luck!
- Build Well -
