Drilled Holes In Floor Joists. - Building & Construction - DIY Chatroom Home Improvement Forum
Old 12-06-2011, 04:30 PM   #1
Drilled holes in floor joists.
I have drilled a hole in a floor joist that is just within 1.75 inches from the bottom of the joist. Code requires 2 inches. What is the fix?
dasherman is offline   Reply With Quote
Old 12-06-2011, 05:29 PM   #2
Tileguy
Bud Cline's Avatar
Rewards Points: 558
What is the fear?
XXX
Old 12-06-2011, 06:11 PM   #3
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 1,248
if your concerned about it. pick up some 3/4" sheathing grade plywood and rip it down to 1/4" less than the dimension of the joist. cut it to 4' lenghts and fasten it centered over the holes both glued and screwed.
this is a standard fix that is engineer approved
woodworkbykirk is offline   Reply With Quote
Old 12-06-2011, 06:29 PM   #4
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Forget about it! Nothing will ever come of a single hole that size in a single floor joist.
If you wake up one morning and your head is poking through the chimney you'll know it all collapsed around you and I was wrong.
XXX
The Following 3 Users Say Thank You to Bud Cline For This Useful Post:
AndyGump (12-06-2011), Big Stud (12-07-2011), MikeKy55 (12-06-2011)
Old 12-07-2011, 04:09 PM   #5
Originally Posted by Bud Cline View Post
What is the fear?
You should be fine if the hole you drilled has not exceeded 25% of the width of the joist.
Mrlemonade is offline   Reply With Quote
Old 12-07-2011, 08:20 PM   #6
Crusty Old Dude
Big Stud's Avatar
I always learn so much from you all
All the best to you and yours, Tom
Big Stud is offline   Reply With Quote
Old 12-07-2011, 09:36 PM   #7
Registered User
Rewards Points: 526
I finally get to use this (even if it is on beams)!!! http://docs.google.com/viewer?a=v&q=...R84KitBdBk9OIA
Don't know why I saved it, I could just ask Bud......LOL.
Gary
The Following User Says Thank You to Gary in WA For This Useful Post:
Bud Cline (12-07-2011)
Holes drilled in windows??? 19mquinn79 Windows and Doors 4 04-19-2011 04:53 PM
Series of holes in periphery of basement slab BalowskiJ Building & Construction 4 04-18-2011 01:49 PM
HELP...Holes drilled in 2 x 4 LBW acfrqflyer Plumbing 1 11-15-2010 01:58 PM
1/2" holes drilled every 3" inches around foundation???? amerren Building & Construction 5 04-13-2010 10:45 AM
Help..drilled holes in storm door wrong... rvegab00 General DIY Discussions 2 09-29-2009 09:42 AM
