Drill Through Or Tapping Steel Plates For Countertop - Building & Construction - DIY Chatroom Home Improvement Forum
Old 06-25-2009, 01:20 PM   #1
dIYHell
Rewards Points: 150
Drill through or Tapping steel plates for countertop
I need to attach a post to a 1/2 steel plate for a countertop. to do this I can either drill through and put the screws in from above or I can drill tap for screws, Ideally I would like to drill and tap but how hard would this be to do with handheld drills and a tap set?
rocketdoctor is offline   Reply With Quote
Old 06-25-2009, 05:11 PM   #2
Hey rocketdoctor, drilling and tapping with hand tools isn't really that difficult. The trick is to drill a hole through a block (aluminum is best) to use as a guide to keep the drill perpendicular to your steel plate. Do the same for the tap. The tap is more critical. A drillpress is perfect for this. This will help your tap stay straight. Depending on your tap size, a small pilot hole will make your drilling much easier. Don't forget to lube the tap.
Hope this helps,
John
John_F is offline   Reply With Quote
Rookie needs advice - How to remove old thinset from concrete floor? rookie floor layer Flooring 9 10-04-2009 12:01 PM
Bosch GSB 16 RE drill Coxy Tools 0 05-28-2009 01:46 AM
"Maintenance Free" Siding Materials (Vinyl, Steel, Fiber Cement) diggitydog Building & Construction 12 01-23-2009 04:24 PM
Basement Renovation Question KUIPORNG Remodeling 234 08-26-2008 08:19 AM
