Drill A Clean 4" Hole In The Exterior Wall - Wood And Vinyl Siding - Building & Construction - Page 2 - DIY Chatroom Home Improvement Forum
Old 03-16-2012, 01:56 PM   #16
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 1,218
the way the vinyl gets cut for the vent depends entirely on the type of vent itself. some are face mounts which require a hold and nothing else.. others are j block style which you install first to the wall then notch the siding to tuck up into then a trim ring goes on
regardless which method, i always line the the openign for a hole with vycor or blueskin starting at the bottom then working my way up around to the top. then lapping the tyvek over top.. then the vent gets set into a bead of caulking on the face of the siding and then a generous bead in around the pipe itself
for a jchannel style i install it then cover the nailing flange with vycor side aroiund it leaving a 1/4- 3/8" gap then slip the trim ring on
woodworkbykirk is offline   Reply With Quote
Vinyl siding over wood siding snorris1 Building & Construction 29 03-02-2012 10:23 PM
Replacing wood siding with vinyl jbjones Building & Construction 33 05-02-2011 12:23 AM
Vinyl siding over wood travem Remodeling 6 02-06-2011 10:32 PM
vinyl siding over wood siding loyal Building & Construction 6 05-26-2009 12:17 AM
Replacing Wood Siding WIth Foam Backed Vinyl xludan Building & Construction 1 05-21-2009 06:27 PM
