Drill A Clean 4" Hole In The Exterior Wall - Wood And Vinyl Siding - Building & Construction - DIY Chatroom Home Improvement Forum
Old 03-15-2012, 06:43 PM   #1
Drill a clean 4" hole in the exterior wall - wood and vinyl siding
I want to cut a hole in the exterior wall to vent the dryer exhaust and will be going through wood and vinyl siding. What is the best tool to do this???
dym1944 is offline   Reply With Quote
Old 03-15-2012, 07:02 PM   #2
Old School
Willie T's Avatar
Saber saw.
Willie T
Old 03-15-2012, 07:03 PM   #3
Rewards Points: 1,470
If you want pretty, you can cut the vinyl and the wood with something like the RotoZip.
Or, if not so pretty is an option, you can cut the vinyl with a sharp razor knife, then drill a bunch of holes in the wood and tap the remaining wood piece out with a hammer.
Either way, the flanges for the dryer vent will cover most but the worst errors...
ktkelly is offline   Reply With Quote
Old 03-15-2012, 07:29 PM   #4
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 1,218
4" hole saw, predrill the pilot hole first so the hole saw doesnt wander.
go very slow and let the saw make the cut.. perfect hole for a dryer vent or bathroom fan
woodworkbykirk is online now   Reply With Quote
The Following 3 Users Say Thank You to woodworkbykirk For This Useful Post:
Gymschu (03-15-2012), mae-ling (03-15-2012), oh'mike (03-16-2012)
Old 03-15-2012, 07:47 PM   #5
Rewards Points: 512
yup definitley the 4" hole saw!
princelake is offline   Reply With Quote
Old 03-15-2012, 08:03 PM   #6
Too Short? Cut it Again!
Sounds like a plan to me! You will need a mandrel if one is not integrated with the saw. Here is the deal though, a saw and mandrel is going to set you back $20-25 on the low but reasonable quality end. I suspect there are even cheaper ones out there that may get you through this project but not many more.
So if this is the only time you would use the hole saw, something like a saber saw will certainly work but a hole saw will be much more precise. Not sure a rotozip type tool will cut deep enough?
Old 03-15-2012, 09:27 PM   #7
firehawkmph's Avatar
Rewards Points: 1,884
Ditto on the hole saw, except get yourself a 4 1/8" hole saw. It is a common size and was made for 4" vent installations. Provides just that extra little bit of clearance for the vent tube to slide in easily. Go easy when going through the vinyl siding. Almost no pressure is needed on the drill. You want to make sure the holesaw starts straight so it doesn't snag the siding. Once you get through the siding, it goes through the wood easily with a little pressure. I usually drill a small hole from the inside so I know where I'm going to end up between the joists.
P.S. Don't drill through the vinyl when its cold out, it will chip then. Above 40 degrees, shouldn't be a problem.
Mike Hawkins
firehawkmph is offline   Reply With Quote
The Following 2 Users Say Thank You to firehawkmph For This Useful Post:
mae-ling (03-15-2012), Tom Struble (03-15-2012)
Old 03-15-2012, 09:43 PM   #8
Rewards Points: 2,212
Sometimes it is better to cut vinyl in reverse.
mae-ling is offline   Reply With Quote
The Following 2 Users Say Thank You to mae-ling For This Useful Post:
bob22 (03-16-2012), oh'mike (03-16-2012)
Old 03-15-2012, 09:51 PM   #9
Tom Struble's Avatar
Rewards Points: 2,002
i agree with Mike if the vent is all metal, i'd go 4 3/8'' if using a vinyl vent
Tom Struble is offline   Reply With Quote
Old 03-15-2012, 10:46 PM   #10
Rewards Points: 13,764
If you plan on using one of these to vent through the siding then the other suggestions are not 100% corrcect.
http://www.accentbuildingproducts.co...specvents.html
Most vents need a square hole in the siding not a round one.
Use a hole saw but only go through one layer at a time, because the plug needs to be removed from the hole saw and the insulation will need to be moved out of the way before boring the next hole.
Once the holes bored through the siding remove the pieces of siding in the area where the hole is. (it's best to try and bore the siding in the middle of a panel not where the seam is.)
Remove the trim ring off of the vent then install the dryer vent to the sheathing (use a 6" torpedo level to check it before nailing.) Then the siding gets cut to fit around the siding block. Make sure there's about 3/8" gap all the way around the siding block so the siding will have room to expand and contract.
Old 03-15-2012, 10:50 PM   #11
don't cut a square hole thru your sheathing make a round hole and cut the siding to fit the vent
and don't forget to flash it
The Following User Says Thank You to Tom Struble For This Useful Post:
user1007 (03-16-2012)
Old 03-15-2012, 10:54 PM   #12
Thanks for making that clearer Tom. That's what I said but someone may have missed that part.
Old 03-15-2012, 11:00 PM   #13
thank you Joe,your replies are always spot on,i for one am impressed by your construction knowledge and your accurate concise answers
this site is lucky you have the time to share your experience,i know ive learned from you
Old 03-15-2012, 11:03 PM   #14
i just didn't want someone to cut a square hole the size of the vent like somebody here didearly in his career
Old 03-15-2012, 11:21 PM   #15
Not everyone on here agrees with you but no one ever does all the time.
We have all done stupid things. That's how we learn.
I tryed to do a direct replacement on a 3-0 6-8 ext. door and it was 3/4" to tall. I standing there trying to figure out how to cut the header, when I realiize I had not removed the shipping block on the bottom of the door.
Went much faster once that was off. lol
I see you do not have your PM set up to recieve messages.
Tom Struble (03-17-2012)
Vinyl siding over wood siding snorris1 Building & Construction 29 03-02-2012 10:23 PM
Replacing wood siding with vinyl jbjones Building & Construction 33 05-02-2011 12:23 AM
Vinyl siding over wood travem Remodeling 6 02-06-2011 10:32 PM
vinyl siding over wood siding loyal Building & Construction 6 05-26-2009 12:17 AM
Replacing Wood Siding WIth Foam Backed Vinyl xludan Building & Construction 1 05-21-2009 06:27 PM
