Drill Bits - Building & Construction - DIY Chatroom Home Improvement Forum
Old 07-05-2012, 10:31 PM   #1
Drill bits
hi,
I am useing cutters to drill holes size 10-14mm through 8-12mm mild steel.The bits tend to snap easily due to vibration of the work surface. Is there a particular make of cutter more suitable for this application other then the standard bit ie. titanium ....?
any reccomendations would be appreciated
james2012 is offline   Reply With Quote
Old 07-05-2012, 10:49 PM   #2
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,648
Ayuh,... What kinda bits are ya using now,..??
Have ya tried a slower speed,..?? Lots, 'n lots of oil,..??
Are they snapping, on break-through,..??
Bondo is online now   Reply With Quote
Old 07-06-2012, 08:58 AM   #3
Bill Kearney
Rewards Points: 1,174
Better secure the material to eliminate the vibration. Clamps come in all kinds of sizes and shapes.
wkearney99 is offline   Reply With Quote
Old 07-07-2012, 10:35 PM   #4
im using standard cutter drill bits , this type shank annular cutters
http://www.jancy.com/index.cfm?fusea...t&productid=76
securing the surface is not possible as its part of a large structure
that vibrates constantly.
sometimes they snap on break through.
would a different alloy cutter make any diffrence? if so wich type?
Tough Drill Bits miamicuse Carpentry 12 01-14-2012 05:40 PM
Black oxide drill bits on metal dasjambo Tools 2 08-15-2011 12:21 PM
Why can't I find straight concrete drill bits? DawsonMobley Tools 13 12-13-2010 12:31 PM
Broken caliper bolt chrissyb Automotive Repairs 12 12-28-2009 03:18 PM
Rookie needs advice - How to remove old thinset from concrete floor? rookie floor layer Flooring 9 10-04-2009 12:01 PM
