DriCore Subfloor - Building & Construction - DIY Chatroom Home Improvement Forum
Old 07-23-2010, 11:05 AM   #1
Rewards Points: 640
DriCore subfloor
I'm in the process or planning out how to redo my basement.... was looking at dri core subflooring (the OSB 2x2 ft toung and groove panels that have the plastic on the bottom with channels for water / air movement) it's about 1/2 inch of OSB with about a 1/4 inch of air space... which is great for basement sub floor since the water would travel to the drains with no problem and helps stop moisture transfer from the floor to the room... my question is how does the room get built when this is in play? do you floor the whole room then builld walls ontop of it or do you built the walls first attach them to the concrete with tapcon scews like you would with the outside perimiter walls then do the drycore around the rooms cutting it to fit?
also anyone here use dri core before? what are your experiences with it?
BlueBSH is offline   Reply With Quote
Old 07-23-2010, 03:41 PM   #2
Framing Contractor
http://www.dricore.com/en/qinstal.aspx
Joe Carola
Joe Carola is offline   Reply With Quote
Tags
basement floor , dricore
Need guidance on subfloor problems in new home. wb1026 Flooring 9 10-06-2009 06:29 AM
Replacing Subfloor whatispunk Flooring 1 09-01-2009 09:50 PM
Subfloor Help, Please! OmahaGirl Flooring 1 01-26-2009 08:06 AM
Subfloor / underlayment question... scheenstra Flooring 7 02-21-2008 07:39 AM
Dricore subfloor nlexi912 Building & Construction 4 01-05-2007 08:44 AM
