Dricore Subfloor - Building & Construction - DIY Chatroom Home Improvement Forum
Old 12-31-2006, 08:21 AM   #1
Question
Dricore subfloor
I am about to add a subfloor to my basement and came across the product Dricore. Does anyone know any info on this product? My plan was to just do 2x4's and plywood until I saw this product. Is also states there should be drains in the concrete, which I have none. I have no water but should I add drains and is this hard to do. Thanks
nlexi912 is offline   Reply With Quote
Old 12-31-2006, 06:09 PM   #2
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
They have a website. You can look up more info. from the manufacturer. We have used it on many basement renovations. I like it and recommend it.
No drains where we have installed it. Never heard of that being a condition for the product.
- Build Well -
Old 01-04-2007, 12:42 PM   #3
Post
I have sent away for my info on dricore. I have just recently priced it and find it much more costly than just using insulation and plywood on the floors. Do you think there would be a big difference in the outcome?
After the dricore is installed then I am gathering that the walls are fastened to that vs the concrete? Also is there any particular wood that is better used for basement walls, I know PT for the bottom plate.
Old 01-04-2007, 08:05 PM   #4
I know that Dricore says that you can attach the walls to their flooring, but we always attach the walls directly to the concrete floor using PT for the bottom plate. Just use KD grade for the walls above.
As far as the difference in price. It's not that much cheaper to use a: vapor barrier, 3/4" plywood, powder actuated fasteners to install a basement floor.
Additionally, read the fact that the Dricore's air chambers actually keep the floor warmer than a floor installed directly over concrete.
- Build Well -
Old 01-05-2007, 08:44 AM   #5
I'd like to hijack for a moment-my apologies.
Would cork tiles work on dricore(didnt see it mentioned on their site)?
I only know that cork should not be used directly on concrete.
Mikedks is offline   Reply With Quote
Need guidance on subfloor problems in new home. wb1026 Flooring 9 10-06-2009 06:29 AM
subfloor question for hardwood installation metrokarl Flooring 2 05-16-2007 08:37 AM
BAthroom Subfloor Blaze25 Flooring 3 11-17-2006 09:06 AM
subfloor for laminate and tiles mf915 Flooring 10 05-18-2006 04:01 PM
COMPLETE subfloor removal alexschmidt Flooring 4 08-02-2005 11:15 PM
