Drainage Behind The Retaining Walls - Building & Construction - DIY Chatroom Home Improvement Forum
Old 10-21-2011, 08:16 AM   #1
drainage behind the retaining walls
objectives and methods of drainage and ground water control??
Kathleen Puyang is offline   Reply With Quote
Old 10-21-2011, 08:29 AM   #2
Rewards Points: 5,336
This is a post from a previous thread.
Are you putting drainage behind the wall? Generally you would dig out behind the wall about 12-18" and install landscape fabric against the soil. Then put a drainage pipe at the base of the wall to carry the water away to a lower area. The pipe would have a sock over it to keep dirt out.
The dug out area would be filled with gravel about 12" from the top. The landscape cloth would be folded over the top and the remaining space filled with soil.
You can also check out You Tube for retaining wall drainage. They have a few good videos.
Ron
B. Franklin 1759
The Following User Says Thank You to Ron6519 For This Useful Post:
concretemasonry (10-21-2011)
recurrent peeling paint on interior walls Krista2 Painting 14 09-10-2011 04:17 PM
Replacing rotten floors under retaining walls babet_h Carpentry 2 09-07-2011 08:36 AM
Need to rebuild outside steps and walls coming from basement doug123 Building & Construction 31 05-03-2010 08:45 AM
Advice on retaining wall replacement (pics inside) eastie Building & Construction 0 04-05-2010 11:32 AM
Best way to repair concrete retaining walls? ohman Landscaping & Lawn Care 2 06-25-2009 12:45 PM
