Drain In The Way Footing Pour - Building & Construction - DIY Chatroom Home Improvement Forum
Old 12-17-2010, 11:51 PM   #1
Drain in the way footing pour
What to do if pouring a column pad footing 48"x48"x12" and abs drain is in the way?
ojee001 is offline   Reply With Quote
Old 12-18-2010, 01:30 AM   #2
Rewards Points: 1,092
If you are just pouring footings, then apparently all is yet exposed. The obvious is "Move the drain", but that I am sure was already ruled out. What is up? Details?
Old 12-18-2010, 02:39 AM   #3
Rewards Points: 4,648
why such a humungous pad ? pls excuse spelling
Old 12-18-2010, 07:16 AM   #4
I am actually asking the same question in 2 threads (new iPhone app) but regardless essentially I removed a load bearing wall on the ground floor and need to pour the footing and install the column in my finished basement. The basement is floating floor on plywood on 2x4 the vapor barrier, 3inch concrete and gravel, finished basement is the reason I don't want to move the drain
Old 12-18-2010, 08:09 AM   #5
Rewards Points: 150
If you got room for a 12 inch thick pad ,then just incase the pipe in the concrete, and just throw some rebar on it, no big deal. You could always put a inch thick steel plate above the pipe if its near the surface.
bernieb is offline   Reply With Quote
Old 12-18-2010, 08:27 AM   #6
Concrete & Masonry
Rewards Points: 568
The pads crazy overkill already, I personally wouldn't worry about pipe and just pour around it. Unless of course there is little concrete cover over it and it is directly under the column.
jomama45 is offline   Reply With Quote
Old 12-18-2010, 09:17 AM   #7
2.0 x 2.0 x 1' deep pad's fine for residential support,,, never have seen any arch spec larger
How does drain pipe around foundation footing end? pttcc Building & Construction 2 09-19-2010 08:46 AM
How to place a floor drain in new concrete pour? walkman Building & Construction 3 10-11-2009 08:18 AM
foundation crack -- uncovering footing AFTER interior drain tile put in? downers Building & Construction 6 05-18-2009 12:07 PM
The Bioswale, french drain, deck, drainage dilemma (long) seabright_sc Building & Construction 2 01-05-2008 03:37 PM
footing drain question chrisk Building & Construction 2 09-02-2007 07:21 PM
