Drain Tile Questions - Building & Construction - DIY Chatroom Home Improvement Forum
Old 03-15-2011, 12:12 AM   #1
Rewards Points: 508
I would like to replace whatever drain tile is installed around the footing of my 1957 raised ranch. I'm going to use of the ez-flow drain tile/synthetic aggregate for the new tile.
I have a couple of questions:
1) Which installation would be preferable (left or right)
benjamincall is offline   Reply With Quote
Old 03-15-2011, 12:16 AM   #2
Rewards Points: 508
Question number two:
When I hit a corner of the house, should I put an elbow in and continue the perforated pipe along the footing or should I tap into a non-perforated pipe and start a new run of pipe with an end cap for the perpendicular wall?
Edit:
3) Wouldn't spending a few extra bucks for 6" pipe make the most sense? I had more water intrusion at the floor-wall joint last week with the heavy rain and snow melt.
No Drain tile to tie egress well into mountain23 Building & Construction 0 09-16-2010 11:29 AM
Terra Cotta tile questions... cocobolo Tiling, ceramics, marble 7 06-04-2010 06:48 PM
French drain tile exterior wall lsaucy Building & Construction 4 05-30-2010 05:22 PM
How to Finish Tile Floor around Drain Hole atm Tiling, ceramics, marble 3 09-12-2009 11:39 AM
Some questions about laying Tile? DiY_RooK Flooring 1 08-31-2007 10:35 PM
