Draftstop Gas Fireplace - Building & Construction - DIY Chatroom Home Improvement Forum
Old 01-18-2010, 09:54 AM   #1
Draftstop gas fireplace
Wondering if anyone has any great tips for draftstopping around a gas fireplace insert?
The unit in question is installed in a basement, inside an old wood burning fireplace and is gas fired-direct vented outside.
The firebox itself seems fine with all draft coming from around the unit itself. It's been finished out in molding and I'd like to avoid ripping that all apart if I can.
Can I use backer rod/foam/caulking around the unit or do I try to seal up the flue chamber somehow to prevent air getting in behind???
jrmac99 is offline   Reply With Quote
new opening in fireplace? burningbaal Remodeling 3 10-11-2009 01:18 PM
New project: removal of old fireplace-replace with a new fireplace! MrShadetree0222 Building & Construction 14 10-16-2008 06:12 PM
convert wood fireplace to gas fireplace brisk Building & Construction 3 06-19-2008 08:17 AM
Possible to build direct-vent fireplace? DIYerself General DIY Discussions 3 12-22-2007 10:07 PM
