04-06-2011, 06:02 AM
#2
Downspouts & Sump Pits
no, they shouldn't, so disconnect the downspout & redirect the discharge on TOP of the ground away from the house,,, see what happens then,,, for appearance, you can always dig & install leader drains later,,, just remember wtr runs downhill &, if it pools, it soaks back into the soil,,, you can add some dye to the drain to see IF it shows up in the sump,,, i'd bet it does
obviously the pump discharge should also drain away from the house
taxpayers voting for obama are as idiotic as chickens who voted for Col. Sanders ! To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
if you hear it from a guy in the apron store, be VERY suspicious the mtl/method will work,,, when it time to build something together, they won't answer phones NOR help To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
