Dow SafeTouch Insulation - Building & Construction - DIY Chatroom Home Improvement Forum
Old 01-03-2011, 11:30 PM   #1
Rewards Points: 197
What's the story on Dow's SafeTouch polyester insulation ?
How's it compare to fiberglass and cellulose ?
Would you use a vapor barrier with it for western Arkansas climate ?
If so, which side should the barrier face for this climate ?
Thanks,
Arky
Arky217 is offline   Reply With Quote
Old 01-04-2011, 12:40 AM   #2
Registered User
Rewards Points: 4,902
I have not used it yet. Compare the density before installing in attic or walls; Dow SafeTouch Insulation
Work the numbers; divide the thickness by 12, times the square footage. Weight divided by the previous product for the density per cubic foot. R-21 = 1.05, R-19 = .65, what did you get for R-30?
Density makes it or breaks it..... Low density, around .50 per cubic foot is the weight of the tested fiberglass that has convective loops; http://www.diychatroom.com/f98/how-b...ulation-90438/
Gary
Cape Cod Style House Attic/Crawl Space Insulation Help Danielg Insulation 24 05-21-2012 09:20 AM
Fiberglass Insulation: How Do I Cover the Attic? chueh Building & Construction 3 11-08-2010 03:33 PM
How To Install Rigid Foam Insulation on Concrete earthad1 Building & Construction 9 10-26-2010 10:49 AM
How hard to install insulation yourself? techprincesse Building & Construction 26 10-17-2009 10:57 AM
Installing new insulation in my basement and removing the old moldy insulation. Fixitgeorge Remodeling 3 10-17-2006 09:33 PM
