Doubling Floor Joists - Building & Construction - DIY Chatroom Home Improvement Forum
Old 01-21-2012, 06:15 PM   #1
Rewards Points: 2,202
doubling floor joists
anyone know of an online span calculator or chart for doubling up floor joists.
1. I vaguely remember from my college days that 2 of anything side by side are twice as stong as one. Is that right?
So can it span twice the distance? NOPE if you put 2x4 and 2x8 in a span calculator it is not 4 times the distance. If you instead make them one on top of the other so 2x4 becomes 2x8 it is 4 times as strong. The point was that depth of joists/beams does more than height.
mae-ling is offline   Reply With Quote
Old 01-21-2012, 06:23 PM   #2
In a little over my head
Rewards Points: 706
I don't know offhand of an online calculator. Oh look; here's one: http://www.awc.org/calculators/span/...rcalcstyle.asp I googled "joist span calculator".
I also remember reading a while back (maybe here) about nailing a 2x4 to the edge of a joist, to form a sort of I-beam. Seems like it had a surprisingly large effect.
ratherbefishing is offline   Reply With Quote
Old 01-21-2012, 06:25 PM   #3
Disabled wood vet
titanoman's Avatar
Rewards Points: 1,004
I don't think doubling up a 16' 2x8 will all of a sudden span 30'.
Stacking, not either. Not even a 12 micro will span that far.
I would think the doubled up's would span further because you can attach one to the other more thoroughly.
titanoman is offline   Reply With Quote
Old 01-21-2012, 06:26 PM   #4
Disabled wood vet
titanoman's Avatar
That's why they call that a strongback.
And attaching a 2x4 to a joist makes the 2x4 stronger, not the other way around.
Old 01-21-2012, 06:28 PM   #5
MarginallyQualified
Rewards Points: 2,464
So can it span twice the distance? NOPE...
I think any real strength only comes when you slip a piece of steel plate in between the two joists (or at least some plywood)
Old 01-21-2012, 06:28 PM   #6
I use that one, it only does 2by material not doubled up ones.
Old 01-21-2012, 06:29 PM   #7
When I mentioned stacking it is going from say 2x4 to 2x8, not just setting one on the other. Should have been clearer.
Old 01-21-2012, 06:33 PM   #8
TarHell - it is amazing what even a thin piece of metal does between 2 pieces of lumber.
Even stuff so thin you can screw or nail right through it.
One time we needed to move a post in a basement remodel. did not want to go wider or deeper with the beam. We were thinking we might use steel. Archy/engineer whoever spec'd a metal plate in-between the plys of the beam. It was less than 1/8 insh I think 1/16th. A while ago.
Old 01-21-2012, 06:36 PM   #9
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 1,006
doubling up wont double the span but it will increase the deflection rating and the ability to take more load on it. as for stacking. ive never heard of this making something stronger unless its finger jointed and bonded with epoxy
unless its ok'd by an engineer i would mess around with it personally
woodworkbykirk is offline   Reply With Quote
Old 01-21-2012, 06:43 PM   #10
just read online someone say it adds 1/3 the original distance. But had nothing else to back it up.
Old 01-21-2012, 07:59 PM   #11
Disabled wood vet
titanoman's Avatar
Okay. I was wondering, like "I've never seen that done before..."
Old 01-21-2012, 09:25 PM   #12
Civil Engineer
Rewards Points: 4,520
The strength of a beam loaded in bending (which is what you get when you impose a uniform load on it) depends on three key factors:
1. The allowable stress (typically abbreviated with Greek letter sigma) in psi
2. The moment of inertia I of the beam. For a prismatic beam (rectangular beam is prismatic) the moment of inertia = bd^3/12, where b is the width, d is the depth, and ^3 means cubed
3. The distance y from the centroid of the beam to the outside edge
The critical equation is Stress = My/I, where M is the maximum bending moment applied, y is the distance from the centroid of the beam to the edge, and I is the moment of inertia.
So let's see what this means in practice. If you double a 2x4 by adding a second 2x4 (sistering), I doubles, y remains the same, allowable stress remains the same, and the strength doubles. This is somewhat harder to achieve in practice than it sounds, because the 2x4's need to be adequately fastened together to act as a unit.
If you double the depth of a beam, say by attaching a second 2x4 to the bottom of the first 2x4, thereby changing the depth from 1-3/4 inches to 3-1/2 inches, you increase the moment of inertia by a factor of 8, since d doubles, and I goes as the cube of the depth. The distance y doubles, since the beam is twice as deep. Assuming you use the same type of lumber top and bottom, the allowable stress does not change, so it turns out that the maximum moment the beam can handle (the strength) goes up by four times. By the way, doubling the depth of a beam is difficult, because you need adequate fasteners to insure that the allowable horizontal shear between the two beams (the top one and the bottom one) is not exceeded, and computation of horizontal shear is tricky. Failure to adequately fasten the top and bottom beams together results in a drastic reduction in strength, and unfortunate behavior of the composite system.
How far you can span is more complex, because the moment typically increases as the square of the span. And computation of deflection (stiffness) is much more complicated, because deflection formulas depend on the modulus of elasticity of the material.
The Following User Says Thank You to Daniel Holzman For This Useful Post:
mae-ling (01-22-2012)
Old 01-21-2012, 10:15 PM   #13
Registered User
Rewards Points: 4,924
I use this one, I've posted it 6-7 times on here before, last one less than a month ago.....send check or money order to:http://www.awc.org/pdf/wsdd/C2B.pdf
Gary
Doubling ground wire on neutral bus bar? dweeter Electrical 1 10-19-2011 06:23 AM
Doubling up backerboard for an exterior wall? joe bag Drywall & Plaster 1 06-04-2011 10:27 AM
Doubling up rafters DbKam Building & Construction 2 10-24-2010 10:16 PM
