Double Wall - Building & Construction - DIY Chatroom Home Improvement Forum
Old 01-28-2010, 09:09 AM   #1
Double wall
I live in an old house that has cement tiles on exterior and plaster interior walls.
Would it be alright to put up another interior wall against original and insulate, and sheet rock, especially on north side of house to try and warm things up in winter?
ironridger is offline   Reply With Quote
Old 01-28-2010, 10:39 AM   #2
Rewards Points: 5,336
Is this the only alternative you came up with? Are there stud walls behind the plaster you could blow insulation into?
An additional stud wall is an option, but an inelegant one.
Ron
Old 01-28-2010, 10:59 AM   #3
Why are you trying to insulate an interior wall ?
Or do you mean build another wall against the exterior wall ?
I would take the inside plaster down & insulate
Adding another wall is not a good idea & just screams of a hack job
Look at the cavity space for rot, bugs etc
Upgrade wiring or run new outlets while the wall is open
Old 01-28-2010, 02:31 PM   #4
Yes there are studs behind plaster and yes it is an outside wall. I thought there could be a way to get a thicker wall for more insulation.
Old 01-28-2010, 03:42 PM   #5
Depending on your definition of "old", there might be no insulation in the wall now. You can check by removing an outlet plate and checking inside the wall next to it.
I have a house built in 1949 and there's 1" of cellulose sandwiched in between what could best be described as tar paper.
Ron
Old 01-28-2010, 03:55 PM   #6
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
If the existing walls are hollow (no insulation), you could tear off the old plaster walls - to the framework. Add framing to build the walls out to accomodate R-19 insulation (5-1/2"), then install new sheetrock/drywall.
- Build Well -
Retaining Wall and Muddy Yard rjschwar Landscaping & Lawn Care 10 02-24-2010 12:55 PM
Double wall pipe Captflx HVAC 4 06-09-2009 12:10 PM
Breaking up a long/continuous wall tigereye Interior Decorating 4 03-08-2009 03:43 PM
Loads on a partition wall acyate Building & Construction 8 02-28-2009 11:02 PM
