Old 03-05-2012, 09:24 PM   #1
Question
Double Up Unistrut/Superstrut
I'm using Unistrut/Superstrut and need to double up. I plan on joining the backs to create the rails on both sides. What is the best bolt size to join the two together? Should I use the 1/2 or 3/8 bolts? Do I use regular washers or the special square ones? How long should they be?
7SistersRanchTX is offline   Reply With Quote
Old 03-05-2012, 09:42 PM   #2
why not buy it that way we do
http://www.unistrut.us/index.php?WP=show&GRP=a_series
depends on size of unistrut i like to use the channel nuts hard to get wrench into channel
http://www.unistrut.us/index.php?WP=...in.%20Hardware
be careful my advice only comes from general knowledge i know about the 4 rules it takes to plumb and they are
1 poop needs to flow down hill. 2 hot on left cold on right
3 i get a pay check on Mondays 4 do not chew finger nails at or after work.
jaydevries is offline   Reply With Quote
Old 03-05-2012, 09:52 PM   #3
I only have access to the single channels. I want to bolt together to look like A1001. The struts I have, have holes in the back wall. Will the Channel nuts twist since they won't contact anything accept the smooth surface? Would I use the 3/8 or 1/2 size bolts
Old 03-05-2012, 10:17 PM   #4
i can not remember if they free spin i am thanking they did not i know i have done this before though and if structure is not an issue i would use the 3/8 easier to get socket in there to tighten
Tags
superstrut, unistrut
Double switch wiring rockclimber Electrical 18 03-18-2012 11:13 PM
Changing A Double Switch to a single pole switch and a dimmer switch loydbrahn Electrical 0 11-09-2011 12:00 AM
double pole breaker + outlets / x10 BlueBSH Electrical 0 09-09-2010 01:44 PM
Eliminating Double Taps in Older Sylvania 200A Panel Reilley Electrical 14 01-11-2009 05:52 PM
How Does A Double Pole Circuit Breaker Trip? shadowx360 Electrical 2 07-09-2008 03:44 PM
