Double Top Plate Question - Building & Construction - Page 3 - DIY Chatroom Home Improvement Forum
Old 09-26-2013, 07:23 PM   #31
Rewards Points: 396
Originally Posted by kwikfishron View Post
Why are you even messing with building trusses for a 6x6 shed? Even one plate or plywood gusset is a waste of time and money for something like that.
Why am I messing with trusses? Cause I need a damn roof!!
detroittigerfan is offline   Reply With Quote
Old 09-26-2013, 08:09 PM   #32
GBrackins's Avatar
Rewards Points: 2,108
I believe what he meant was it would be simple to frame your roof using traditional framing such as rafter, ridge board and ceiling joists.
I think we all understand you do not want water intrusion.
Gary
"You get what you pay for, and sometimes free costs more!"
GBrackins is offline   Reply With Quote
Old 09-26-2013, 10:18 PM   #33
Rewards Points: 396
I was thinking of going with that but with just one person its much easier installing using trusses since I can put them up one at a time. Do you think you could look this up please and just give me your opinion on if you think this is good enough for the truss joints. I put a link below.
http://www.homedepot.com/p/Simpson-S...4#.UkTq6tKkoZ4
Old 09-26-2013, 10:19 PM   #34
Rewards Points: 396
Thanks.
Old 09-26-2013, 10:20 PM   #35
GBrackins's Avatar
for what you're doing it'll probably work, not like there is a tremendous load on your roof
Gary
Old 09-26-2013, 10:21 PM   #36
Rewards Points: 396
I mean its that or those plywood gussets. Don't you think the metal plates would be stronger than the plywood?
Replacing sill plate - foundation wall repair NWChris Building & Construction 0 09-14-2013 01:05 PM
Double feed question. mlijoi Electrical 5 01-06-2013 05:49 PM
Replacing Section of Sole Plate RM575 Carpentry 3 03-28-2010 10:31 AM
Sill plate and rim joist question bhasty Building & Construction 3 10-15-2009 03:07 PM
Basement vapor barrier question rob7young Remodeling 2 04-13-2008 10:10 AM
