Double Top Plate Question - Building & Construction - Page 2 - DIY Chatroom Home Improvement Forum
Old 09-26-2013, 12:57 PM   #16
Rewards Points: 396
Originally Posted by GBrackins View Post
do you have to pass any inspections?
no inspections nor would I get one anyways.
detroittigerfan is offline   Reply With Quote
Old 09-26-2013, 12:58 PM   #17
Rewards Points: 396
Plus I can run some metal bracing strips along the top plate to tie the corners together.
Old 09-26-2013, 02:19 PM   #18
GBrackins's Avatar
Rewards Points: 2,108
oh, ok
Gary
"You get what you pay for, and sometimes free costs more!"
GBrackins is offline   Reply With Quote
Old 09-26-2013, 03:06 PM   #19
cortell's Avatar
Rewards Points: 504
it depends on the type of truss
To illustrate the point:
cortell is offline   Reply With Quote
Old 09-26-2013, 03:35 PM   #20
Rewards Points: 396
Just curious what is the point of a cantelivered truss when you can just extended the top chord for an overhang?
Old 09-26-2013, 03:39 PM   #21
GBrackins's Avatar
for one, don't have to worry about sheathing thickness ....
gives higher soffit height too, easier to use if walls are not square or level to name a few
Gary
Old 09-26-2013, 03:50 PM   #22
cortell's Avatar
Rewards Points: 504
Besides aesthetic tastes, a cantilevered truss doesn't sacrifice clearance. This is particularly important with steep pitched roofs.
Old 09-26-2013, 03:51 PM   #23
Rewards Points: 396
Ok I see. I started putting together some trusses for a shed roof. I am using Simpson Strong Tie TP35 3-1/8" x 5" for the chord joints. Its something I just thought of and started using because I was told to not use the mending plates with the metal teeth and the ones at the store say not for trusses on them. Please let me know what you think.
Old 09-26-2013, 03:58 PM   #24
GBrackins's Avatar
what is your roof pitch?
Gary
Old 09-26-2013, 04:06 PM   #25
Rewards Points: 396
7/12 for a 6x6 shed.
Old 09-26-2013, 04:13 PM   #26
Rewards Points: 396
I see online where they use plywood gussets but don't you think these mending plates would be stronger?
Old 09-26-2013, 04:19 PM   #27
cortell's Avatar
Rewards Points: 504
Hm. I'm having Deja Vu. See Roof truss tie plate
The Following User Says Thank You to cortell For This Useful Post:
kwikfishron (09-26-2013)
Old 09-26-2013, 04:26 PM   #28
It's like Groundhog Day only with truss mending plates / plywood
RoyalAcresRod is offline   Reply With Quote
The Following 2 Users Say Thank You to RoyalAcresRod For This Useful Post:
cortell (09-26-2013), sixeightten (09-26-2013)
Old 09-26-2013, 04:41 PM   #29
Rewards Points: 396
For a small 6 by 6 shed do you guys think im good using the Simpson Strong Tie TP35 3-1/8" x 5" mending plates instead of plywood gussets?
Old 09-26-2013, 05:44 PM   #30
kwikfishron's Avatar
Rewards Points: 772
Why are you even messing with building trusses for a 6x6 shed? Even one plate or plywood gusset is a waste of time and money for something like that.
kwikfishron is online now   Reply With Quote
The Following User Says Thank You to kwikfishron For This Useful Post:
hand drive (09-26-2013)
Replacing sill plate - foundation wall repair NWChris Building & Construction 0 09-14-2013 12:05 PM
Double feed question. mlijoi Electrical 5 01-06-2013 04:49 PM
Replacing Section of Sole Plate RM575 Carpentry 3 03-28-2010 09:31 AM
Sill plate and rim joist question bhasty Building & Construction 3 10-15-2009 02:07 PM
Basement vapor barrier question rob7young Remodeling 2 04-13-2008 09:10 AM
