Double An Outside Wall Inside - Building & Construction - DIY Chatroom Home Improvement Forum
Old 11-30-2011, 03:50 AM   #1
Double an outside wall inside
I was thinking about adding insulation to the outside walls of my house. Instead of tearing out the lath and plaster inside, and making a big mess, would it be okay to build a 2x4 wall over it all, adding a new vapor barrier? Someone said I would want to break holes in the old wall, but I don't know why. Would I be able to attach the top plate to the ceiling joists through the ceiling without tearing it out?
Woodrat is offline   Reply With Quote
Old 11-30-2011, 05:57 AM   #2
DIY staff
Rewards Points: 7,174
You could do that--but why?
There are costs involved that make that idea impractical---Why not just remove the lath and plaster?
Old 11-30-2011, 06:58 AM   #3
JOATMON
ddawg16's Avatar
Rewards Points: 820
Your location has a lot to do with it.....
If the climate is right....maybe use insulated vinyl siding? You could toss on sheets of 1" foam and then put the insulted vinyl on top of that.
Remortaring inside of foundation wall strategery Building & Construction 3 10-20-2011 01:25 AM
Flared connections inside wall in Massachusetts (Mitsubish Mr. Slim) ChootarLaal HVAC 5 07-21-2011 09:27 PM
Insulating between joists with double brick wall. rugby style Building & Construction 3 12-20-2010 03:25 PM
run spliced lamp cord inside a wall? denemante Electrical 20 12-17-2010 10:35 PM
