Double Header/beam Connection - Building & Construction - DIY Chatroom Home Improvement Forum
Old 04-09-2015, 10:13 AM   #1
Rewards Points: 700
double header/beam connection
On a corner post where the header rests on top of the post then runs 90 degrees to wrap around....how is the connection between post and beam made? Is there a hanger that is used or is one side of the header run longer and then tied into the other header running perpendicular? It's a doubled 2x8 header and a 4x4 size post.
cibula11 is offline   Reply With Quote
Old 04-09-2015, 11:30 AM   #2
Rewards Points: 700
I was thinking of this....to give an idea:
http://www.qualitydist.net/sst-lce4z.html
Old 04-09-2015, 11:48 AM   #3
Rewards Points: 1,390
if you are building a deck, you can avoid this connection by running your beam long setting directly on your post, then hang your perpendicular beam using using a double joist hanger bracket
let us know how your project turns out!
Yodaman is offline   Reply With Quote
Old 04-09-2015, 01:17 PM   #4
Rewards Points: 700
It is for porch roof....the beam is the header and the posts are the columns. Could this still be done as you suggested above.
Old 04-09-2015, 01:42 PM   #5
Rewards Points: 4,560
Have you check to see if a 4 X 4 would even be allowed?
Main reason is 4 X 4's love to curl, and twist.
Have to use 6 X 6's here sitting on footers.
http://www.strongtie.com/products/co...urce=capsbscat
Old 04-09-2015, 02:39 PM   #6
If you are building a plane shed roof then yes, if hip style then you will need the 90 degree corner connection. Joe is right 4 x 4s are light for post, they would need to be close, 6 x 6s might be a better choice. I used turned treated post for a small 7 x 16 porch roof once, but the post were 48" apart.
Old 04-09-2015, 05:16 PM   #7
Rewards Points: 700
It will be a hip as it wraps around the side. It's a fairly small porch...only extending 6'. Bc of the placement of existing windows and doors we're spacing them 6' apart. We'll end up with 12 total posts around a 16x16 area. Using 6x6s might be easier to work with, but the roof extends lower than normal so we didn't want the bulk of a 6x6, since we will be using a doubled 2x8 header.
I did call our building inspector and he said 4x4 wood posts or 4x4 pvc reinforced posts would be acceptable. Fwiw our wood posts will be covered with a vinyl sleeve.
The Following User Says Thank You to cibula11 For This Useful Post:
mae-ling (04-09-2015)
Old 04-12-2015, 08:33 AM   #8
Rewards Points: 1,338
You can stagger the outside and inside beams (of a double beam). Reinforce with recessed metal angles. You probably will need a cross brace?
carpdad is offline   Reply With Quote
Changing out this gas 'connection' joemc3 Plumbing 55 03-22-2014 03:00 PM
Taking Clad Double Hung apart to create smaller fixed windows KJinCton Windows and Doors 2 10-07-2013 04:26 PM
Help Requested for Changing Double Switch to Two Singles eddj Electrical 27 12-01-2012 01:04 AM
Double switch and single switch in same box? Mallard1123 Electrical 2 09-19-2012 11:06 AM
Telephone Jack Connection Problem jogan Electrical 9 04-20-2009 06:10 AM
