Double Entrance Door Security - Building & Construction - DIY Chatroom Home Improvement Forum
Old 11-18-2010, 09:49 AM   #1
Rewards Points: 85
Double entrance door security
Our entrance door is double door design, the lock on one side has 2 sliders, one on top and one at the bottom to slide into the door frame, the other door lock onto this one.
The lock seems flimsy to me, talked to the door and window security store, not much can do with this design, they said.
Anyone of you have success to reinforce the locking mechanism of this door design or make it more secure?
quincy is online now   Reply With Quote
Old 11-18-2010, 10:10 AM   #2
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,088
Ayuh,... Just How secure do ya need it,..??
I imagine it'll stop a person without tools as it is...
I don't think they make doors that'll stop a well equiped criminal...
Bondo is online now   Reply With Quote
Old 11-18-2010, 12:06 PM   #3
Rewards Points: 88
I am not a security expert, but just like any door, I would want all of the bolts, top, bottom, standard, and deadbolt, to have enough throw to go beynd the casing, and into the "meat", so you should probably look at that, but otherwise, I don't think that I would assume them to be any less secure than a standard door. If these are wood doors with wood casings, I also suggest that you install longer hinge screws, at least the two center-most ones in each hinge, as, in my opinion, this is an often overlooked weak link.
Double switch wiring rockclimber Electrical 18 03-18-2012 10:13 PM
Double Hung vs Single Hung CZSteve Remodeling 0 11-08-2010 07:29 AM
double pole breaker + outlets / x10 BlueBSH Electrical 0 09-09-2010 12:44 PM
Eliminating Double Taps in Older Sylvania 200A Panel Reilley Electrical 14 01-11-2009 04:52 PM
How Does A Double Pole Circuit Breaker Trip? shadowx360 Electrical 2 07-09-2008 02:44 PM
