Dormer Addition - Building & Construction - DIY Chatroom Home Improvement Forum
Old 06-19-2011, 11:31 AM   #1
Dormer Addition
I have a home with 2 floors would I be able to add a dormer to the second floor?
Sclarke is offline   Reply With Quote
Old 06-19-2011, 01:29 PM   #2
Framing Contractor
Yes, you can. What type of dormer?
Joe Carola
Joe Carola is offline   Reply With Quote
Old 06-19-2011, 02:08 PM   #3
That's the thing Joe I don't know and I have three bedrooms on the the second floor with 1 bath and I want to have a master suite with with closet and bath.
Old 06-19-2011, 03:01 PM   #4
Residential Designer
AndyGump's Avatar
Rewards Points: 688
Send a message via Skype™ to AndyGump
IF I can state the obvious, you need to hire a designer or a design build construction firm.
Andy.
AndyGump is offline   Reply With Quote
Old 06-19-2011, 03:12 PM   #5
Thank you Andy I pretty much figured that. Just wanted to make sure I could do it with the second floor in place already. I've been told that when there is a second floor and just a dormer addition that it's usually a easy job.
Asphalt shingles on vertical wall dormer helpplease! Roofing/Siding 2 12-13-2010 06:47 AM
Thoughts on this addition? sportinwla HVAC 13 04-20-2009 04:12 AM
Footing/Foundation for Addition stubits Building & Construction 1 03-11-2009 01:43 PM
!!HELP!! Rain leaking between existing home and new addition NJGirl357 Roofing/Siding 4 09-10-2008 05:06 PM
Home Addition cost? Russ Chewning Building & Construction 3 10-23-2006 07:59 PM
