Doors Or Sheetrock? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 01-01-2012, 09:50 AM   #1
Doors or Sheetrock?
Stupid question here....I think I know the answer, but wanted to see other's opinions....
I'm at the sheetrock stage of my basement finish, and wondered if I should hang the interior prehung doors before I start sheetrock.
Thanks in advance
lowvolter is offline   Reply With Quote
Old 01-01-2012, 09:53 AM   #2
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,142
Hang the rock first.
Coastal South Carolina
rjniles is offline   Reply With Quote
Old 01-01-2012, 09:54 AM   #3
DIY staff
Rewards Points: 7,174
NO!!!!!
Get the mess out of the way before adding any trims or finished materials---
Old 01-01-2012, 10:01 AM   #4
That was my initial thoughts...thanks guys
The Following User Says Thank You to lowvolter For This Useful Post:
oh'mike (01-01-2012)
Old 01-01-2012, 10:26 AM   #5
Rewards Points: 13,300
Rock first so all the dust, primer and paint do not get on the doors. Also far faster to paint with a roller around the doorways with no cutting in to do.
mae-ling (01-01-2012)
Old 01-01-2012, 10:39 AM   #6
Framing Contractor
The main reason is because you flush the door jambs to the sheetrock when hanging the doors.
Joe Carola
Joe Carola is offline   Reply With Quote
The Following User Says Thank You to Joe Carola For This Useful Post:
woodworkbykirk (01-01-2012)
Old 01-01-2012, 03:54 PM   #7
Rewards Points: 2,210
Also easier to cut the rock when the doors not in. Just drywall over the hole and cut out after (top sheet) then on the bottom if you have say a 7' space beside the door put in a 8' and cut it in place.
mae-ling is offline   Reply With Quote
Old 01-01-2012, 09:59 PM   #8
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 1,058
having door jambs and window boxes in place also makes it a major pain in the butt for the taper, ive known gc's that want to get a jump on the trim.. when the board hangers show up they simply tear out the door frames or leave the site until someone else removes them
woodworkbykirk is offline   Reply With Quote
Reality check on interior doors recently delivered PatBB Carpentry 8 09-05-2011 06:36 PM
3/8 Sheetrock joint at ceiling and at doors tuckerz Remodeling 3 10-11-2009 06:53 PM
How soon can I install Masonite doors after sheetrock? cej22 Carpentry 6 07-09-2009 09:11 AM
Interior Doors before Sheetrock? mtmkgirl Building & Construction 12 05-23-2008 02:05 PM
