Doors Opening Next To Walls - Building & Construction - DIY Chatroom Home Improvement Forum
Old 12-12-2010, 05:19 PM   #1
Doomed DIY'er
Doors opening next to walls
I'm framing a room in my basement. The ceiling is on the short side, so the cripple studs will be played by scraps of OSB.
I have been able to find a lot of information on framing walls and doors, however, I have not been able to find any reccomendations on framing doors that are adjacent to walls. How far out does the door frame need to be from the adjoining wall to prevent interferance?
Below, I have a computer model which would have it framed out 3" from the wall (thickness of two 2X4's). Is that acceptable or should I add some space between the king stud and the ajoining wall? Drywalling such a small strip seems like it could be quite troublesome. What's the right way to frame that corner and position the door?
clayman is offline   Reply With Quote
Old 12-12-2010, 05:26 PM   #2
kwikfishron's Avatar
Rewards Points: 368
3” is fine unless your going with a wide door trim detail.
kwikfishron is offline   Reply With Quote
Need to rebuild outside steps and walls coming from basement doug123 Building & Construction 31 05-03-2010 07:45 AM
Interior door swelling? jdeters79 Remodeling 9 08-15-2009 10:51 AM
Finishing opening for closet Frank_N_Stein Carpentry 11 12-24-2008 08:52 PM
Keeping Water out of the Top of Brick Walls o2barockstar Roofing/Siding 4 02-18-2008 02:50 PM
Home Made Closet Doors allen1466 Building & Construction 9 10-25-2007 04:57 PM
