Doors - Building & Construction - DIY Chatroom Home Improvement Forum
Old 09-07-2009, 12:14 AM   #1
doors
Hi,
Is it possible to install two doors in 770mm opening on a 45 degree angle and if it is how do you do it
Irwinbuilt
irwinbuilt is offline   Reply With Quote
Old 09-07-2009, 01:25 AM   #2
Registered User
Termite's Avatar
Any chance of you converting 770mm to inches for us? Most of us here don't do as well with the metric system.
Not sure what you mean by 45 degree angle either. The wall is 45 degrees to the other walls?
When you talk about two doors do you mean french doors?
In order to help you we're going to need a lot more detail and some pictures of the opening would help as well.
Old 09-07-2009, 02:39 AM   #3
Rewards Points: 582
770mm is approx 30 1/4 inches, which makes 2 very small doors.
stuart45 is offline   Reply With Quote
Installing closet doors into un-true opening - Need ideas McCool Carpentry 8 08-12-2009 01:37 PM
pocket hole joinery for cabinet doors? Jeremy Hillary Boob, PhD Carpentry 4 03-09-2009 05:26 PM
UGH! A lesson for new Pre-Hung Doors javan General DIY Discussions 6 08-08-2008 07:47 PM
It's hot outside. Keep the exterior doors and windows closed if running the A/C? Taylor Crockett HVAC 3 07-07-2008 05:04 PM
French Doors That don't Match! terryb Building & Construction 21 12-17-2007 07:19 PM
