Doors - Building & Construction - DIY Chatroom Home Improvement Forum
Old 02-02-2013, 10:06 AM   #1
Doors
My front door is in the closed postition. The door knob is locked and we cannot get it unlocked. We can get the knob to turn partially but not all the way. We have tried taking the knob off and manually working with the inside of the set, but cannot seem to get it to budge.
sambola is offline   Reply With Quote
Old 02-02-2013, 10:54 AM   #2
I run in to this all the time at my job. Your door has settled and the knob latch is binding in to the strike. You need to get the door raised by adding a lag screw in the top hinge. For now lift the door by pulling at a upward angle on the knob. The other thing it could be if it is a kwikset you might have a frozen latch in which case your gonna have to pull the knob and get a scribe to pull in the actual lip.
SoCoSpartan is offline   Reply With Quote
Old 02-02-2013, 12:18 PM   #3
Rewards Points: 1,294
How old is the knob set. Sometimes these things fail to the point they can not move as something gets so out of wack that it gets hung up. Most times doing what you did, removing the handle/knob, will allow you to get it open. I have had some where I had to use a sawzall to cut the offending part between the door and the door jamb. Of course this requires replacing the lockset.
danpik is offline   Reply With Quote
Old 02-02-2013, 12:28 PM   #4
funfool's Avatar
Rewards Points: 534
I would just pull the hinge pins and remove the door, replace lock set if needed or might just need to be adjusted by adding a 3" screw in top hinge.
Really need to get the door open first.
funfool is offline   Reply With Quote
The Following User Says Thank You to funfool For This Useful Post:
woodworkbykirk (02-02-2013)
Old 02-02-2013, 01:30 PM   #5
Rewards Points: 13,270
A lag bolt
Old 02-02-2013, 11:39 PM   #6
I did not say a lag bolt. A lag screw or a 3" exterior grade screw if you prefer smart guy.
Made My Own Inexpensive Wood Garage Carriage Doors iffy Project Showcase 4 03-31-2012 03:07 PM
Repair or Replace Garage Doors??? jbird0005 Windows and Doors 2 12-10-2011 07:42 AM
Reality check on interior doors recently delivered PatBB Carpentry 8 09-05-2011 06:36 PM
It's hot outside. Keep the exterior doors and windows closed if running the A/C? Taylor Crockett HVAC 3 07-07-2008 06:04 PM
