-   -   Doors (http://www.diychatroom.com/f19/doors-170816/)
sambola 02-02-2013 10:06 AM
Doors
My front door is in the closed postition. The door knob is locked and we cannot get it unlocked. We can get the knob to turn partially but not all the way. We have tried taking the knob off and manually working with the inside of the set, but cannot seem to get it to budge.
SoCoSpartan 02-02-2013 10:54 AM
I run in to this all the time at my job. Your door has settled and the knob latch is binding in to the strike. You need to get the door raised by adding a lag screw in the top hinge. For now lift the door by pulling at a upward angle on the knob. The other thing it could be if it is a kwikset you might have a frozen latch in which case your gonna have to pull the knob and get a scribe to pull in the actual lip.
danpik 02-02-2013 12:18 PM
How old is the knob set. Sometimes these things fail to the point they can not move as something gets so out of wack that it gets hung up. Most times doing what you did, removing the handle/knob, will allow you to get it open. I have had some where I had to use a sawzall to cut the offending part between the door and the door jamb. Of course this requires replacing the lockset.
funfool 02-02-2013 12:28 PM
I would just pull the hinge pins and remove the door, replace lock set if needed or might just need to be adjusted by adding a 3" screw in top hinge.
Really need to get the door open first.
joecaption 02-02-2013 01:30 PM
A lag bolt:eek:
SoCoSpartan 02-02-2013 11:39 PM
I did not say a lag bolt. A lag screw or a 3" exterior grade screw if you prefer smart guy.
