Door Threshold - Building & Construction - DIY Chatroom Home Improvement Forum
Old 11-24-2013, 12:01 PM   #1
Rewards Points: 396
Door threshold
What is the best way to level a door threshold that sits on a slightly unlevel concrete slab?
detroittigerfan is offline   Reply With Quote
Old 11-24-2013, 01:22 PM   #2
Rewards Points: 12,830
I cut a tapered shim to act as a form and use non gypsum floor leveler.
Once all I had on site was hydraulic cement and it also worked. Just have to move fast because it hardens so fast.
Old 11-24-2013, 01:24 PM   #3
Rewards Points: 396
When you apply floor leveling compound on the concrete how do you gauge how much to add?
Old 11-24-2013, 01:46 PM   #4
Use a 4' level, lay it on the floor and bump it up against the wall.
Lift one end of the level until it's level, measure from the floor to the bottom of the level.
Old 11-24-2013, 01:49 PM   #5
Rewards Points: 396
Can you simply use wood shims under the threshold or a self leveling compound?
Old 11-24-2013, 01:56 PM   #6
The shim I suggested are for nothing but making a from to temporarily give you a level area to work off of while applying the leveler.
http://www.homedepot.com/p/Custom-Bu...2#.UpJLZhMo7IU
You never want to just shim under a threshold. It needs 100 direct contact.
