Door Swing And R.O. Question - Building & Construction - DIY Chatroom Home Improvement Forum
Old 01-04-2013, 02:56 PM   #1
Door Swing and R.O. Question
I am replacing an old pre-hung interior door with a new one. I was thinking it was a 36" door, when I measured the r.o. it was 35 3/4, so I would need a 34" pre-hung door, is this right ? That doesn't seem to be a common size carried in the stores . . .
Second question, is the picture attached a right inswing door ?
barley is offline   Reply With Quote
Old 01-04-2013, 03:02 PM   #2
Rewards Points: 13,748
You measure the door not the RO.
Stand in the room it's servinig, reach out to turn the knob, which hand are you using, that's the swing.
Residential doors swing into the room, commercial doors open out.
Old 01-04-2013, 03:05 PM   #3
The door is for a closet, so I need to be able to pull the door towards me as I am standing in front of it, that is where I am getting confused.
Old 01-04-2013, 03:19 PM   #4
Ole Wood Worker
BigJim's Avatar
Rewards Points: 400
Stand in the doorway with your back to the hinge, if the door swings to the right it is a right hung door, if it swings to the left it is a left.
New members: Please consider adding your location to your profile.
If you do what you've always done, you'll get what you've always got.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is offline   Reply With Quote
The Following User Says Thank You to BigJim For This Useful Post:
kwikfishron (01-04-2013)
Old 01-04-2013, 03:46 PM   #5
The drawing you posted looks like an out swing not an in swing.
http://www.naturalhandyman.com/iip/i...fdoorhand.html
Old 01-04-2013, 03:50 PM   #6
See, this is where I have so much confusion, maybe I am just over complicating it in my head. Is the picture a right inswing, or left outswing. . . or are they the same thing ?
Old 01-04-2013, 03:53 PM   #7
kwikfishron's Avatar
Rewards Points: 610
The way Jim described it (back to the hinges) is how I’ve always known it.
The only time in-swing or out-swing come into play (when ordering) is if there’s a threshold (exterior door).
What you have is simply a "right hand door"
kwikfishron is online now   Reply With Quote
The Following 2 Users Say Thank You to kwikfishron For This Useful Post:
barley (01-04-2013), BigJim (01-04-2013)
Old 01-04-2013, 03:56 PM   #8
Ole Wood Worker
BigJim's Avatar
Rewards Points: 400
From your drawing it looks like an outswing right hung, but it makes no difference if it swings in or out, that door is still a right hung door.
Jim
barley (01-04-2013)
Old 01-04-2013, 03:56 PM   #9
Okay, that makes it much more clear. So for this picture, I would get a 34" left swing door
Old 01-04-2013, 03:58 PM   #10
I meant to type Right in the last post, not left.
Old 01-04-2013, 04:13 PM   #11
Rewards Points: 610
Whether it’s right “hand”, “hung” or “swing” it’s all the same, just a difference in regional terminology.
The Following User Says Thank You to kwikfishron For This Useful Post:
BigJim (01-04-2013)
Old 01-04-2013, 06:26 PM   #12
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 1,214
ok.. everyones noticing the swing, im the only one that picked up on the fact that the rough opening is too small for a 34" door prehung. you need a minimum of 36" for a 34" to go in it. . always make the r.o a minimum of 2" larger than the size of the door itself. sometimes the r.o has to be 2 1/2" larger depending on how plumb the jack studs are and how thick the jamb material is
woodworkbykirk is offline   Reply With Quote
Old 01-04-2013, 06:35 PM   #13
Rewards Points: 610
Oh ya...that too.
OP said that he/she had a 35 3/4" RO which should be just fine "if" the framing is plumb.
Old 01-04-2013, 07:12 PM   #14
funfool's Avatar
Rewards Points: 534
You need to measure the opening not the door.
A standard 36" door, A new blank will measure 35 3/4" is typical.
The actual opening with the existing door removed. should be 39" or 3" bigger for the door jambs to be installed properly.
But yeah, a actual 36" door measures 35 3/4", the hole it goes into will be different.
funfool is offline   Reply With Quote
Old 01-04-2013, 07:26 PM   #15
a 36" door is 36" .. even with the lean of the door if it has the bevel put on it your not going to lose that much width
if its a 36" bifold then its 35 1/4
The Following User Says Thank You to woodworkbykirk For This Useful Post:
