Door Meets Last Step On Basement Staircase.. - Building & Construction - DIY Chatroom Home Improvement Forum
Old 08-28-2012, 11:56 PM   #1
Rewards Points: 77
Door Meets last step on basement staircase..
I am finishing my basement and my basement stairs come down to about less than 28" from my framed wall.
My plan is to put the door at the bottom of the stairs to a room (the doorway is pictured).
I want to put a 30-32" door there, however, the last step would then jut out into the bottom corner of the door when opened (door will open into the room).
Is this allowable by code, if the corner of the step opens into the doorway?
I can put in a door smaller than 28" but I wanted something wider, so that if needed I could get things back into the small storage area.
Thoughts?
troyce1 is offline   Reply With Quote
Old 08-29-2012, 12:34 AM   #2
Registered User
Rewards Points: 5,228
You need a 36" landing at the bottom, check with local AHJ: http://publicecodes.cyberregs.com/ic...?bu2=undefined
Gary
Gary in WA is online now   Reply With Quote
The Following User Says Thank You to Gary in WA For This Useful Post:
mae-ling (08-29-2012)
Old 08-29-2012, 12:38 AM   #3
Rewards Points: 77
@GBR, thanks, but the basement height with stairs would not allow that. The house is over 160 years old, so the spaces etc are much tighter.
Old 08-29-2012, 01:12 AM   #4
Rewards Points: 13,300
Put the door at the top of the stairs opening into the room up stairs.
Old 08-29-2012, 08:48 AM   #5
Rewards Points: 77
@Joe - There already is a door at the top of the stairs.
I just wanted to put a seperate door in for privacy/access.
There is also a 30" exterior door on the opposite wall.
Old 08-29-2012, 09:06 AM   #6
GBrackins's Avatar
Rewards Points: 2,108
Were you required to obtain a permit to perform this work? Will the building inspector be checking your work?
Gary
"You get what you pay for, and sometimes free costs more!"
GBrackins is offline   Reply With Quote
Old 08-29-2012, 09:26 AM   #7
bbo
pocket door option?
bbo is offline   Reply With Quote
Old 08-29-2012, 09:26 AM   #8
Rewards Points: 150
Doesnt mean it doesnt have to pass code, they dont let you slide because its old and tight.
If my advise helped you hit "Thanks"
Hammer450R is offline   Reply With Quote
Old 08-29-2012, 11:55 AM   #9
Rewards Points: 77
@BBO - a pocket door still would pose the same issue, either have a 24" door, or have the bottom stair exposed when the door is open.
@GBrakins - no permit, we are replacing the existing framing, we had to tear it out to waterproof the basement.
It seems that there is no ideal option here. I looked at building the bottom stair into a landing which would be 36" but then the ceiling height is too low to stand up, a wider door will leave the bottom stair exposed when open, and a small door is just.... small.
I dont see any feasible way to have 36" at the bottom of the stairs w/o building the landing thus reducing the stair height.
Old 08-29-2012, 01:03 PM   #10
GBrackins's Avatar
what is the distance from the bottom of the stairs to the 2x wall?
Gary
Old 08-29-2012, 01:38 PM   #11
Rewards Points: 77
It is either 24.5" or 26.5", I will be able to check in about an hour for sure.
Old 08-29-2012, 01:41 PM   #12
GBrackins's Avatar
no need to measure if it's that short of 36". I have seen similar in older homes for stairs down to the basement
Gary
Old 08-29-2012, 01:56 PM   #13
Rewards Points: 77
Gbrakins- what are you suggesting? Just leave it ?
If I leave the wall framing coming down the stairs as is with the bottom step exposed I can get a 30" there. I'm not sure what's worse...a small door or the step exposed ?
Old 08-29-2012, 03:07 PM   #14
GBrackins's Avatar
I was suggesting there was no need for you to measure the distance .... that's all
Gary
Old 08-29-2012, 03:07 PM   #15
GBrackins's Avatar
do you have a building code? if so what is it?
Gary
Advice on finishing my basement? jakec202 Remodeling 1 07-06-2012 04:11 PM
Basement Staircase rubots12 Building & Construction 14 11-19-2011 01:34 AM
Basement staircase code Clutchcargo Building & Construction 20 11-12-2009 11:06 PM
Unfinished step around wood laminate floors markq Flooring 7 07-17-2009 08:19 PM
basement floor drain problem radioiowa88 Plumbing 5 10-22-2008 11:52 PM
