Old 08-16-2010, 10:52 PM   #1
Door Knob - very odd
I've never encountered this kind of doorknob before.
I know door knobs are like 101 but this one is really weird.
please help if you can.
http://www.bonam.com/doorknob-help
Quick explanation:
The door knob that can be removed is on the OUTSIDE.
I remove it, easy peasy.
INISDE door knob doesn't have a slot or any way to remove it.
INSIDE door knob back plate houses screws.
Cannot access screws unless I remove INSIDE door knob.
i'm stuck..
PLS HELP!
thank you
bonam is offline   Reply With Quote
Old 08-17-2010, 03:20 PM   #2
SOLVED.
turns out there WAS a hole in the inside doorknob to remove it, but it was obscured by the back plate. I had to bend the backplate to access it.
Thanks anyways.
