Door Knob Faceplate Unscrews - Building & Construction - DIY Chatroom Home Improvement Forum
Old 09-14-2010, 06:38 AM   #1
door knob faceplate unscrews
on severak of my interior doors the Gainsborough door knob face plate unscrews and sometime that handle assembly falls off which
could injure the person has the experience. I have tried to tighten the face plates by hand using a non-slip rubber square but the faceplates always loosen up again. How can I stop this problem?
anfried is offline   Reply With Quote
Old 09-14-2010, 06:53 AM   #2
Rewards Points: 79
Screws generally don't loosen up unless they're not tightly held by the wood into which they're driven. Remove the screws and plates clean any loose particles out of the screwhole (shop vac ) get some decent shim material (oak or similar hardwood) whittle it down so that it can be driven into the screw holes and be snug as you near the end of the drive, and glue it as you drive it in. Allow it to dry before cutting it off. Then redrill your pilot holes at a size that will allow the screw to have good bite.
If you don't have time to do it right, when will you ever have time to do it over?
jackofmany is offline   Reply With Quote
Old 09-14-2010, 07:02 AM   #3
Your suggestion is right on but my face plate is not held on by screws through the plate. The back of the plate has a thread around the perimeter so the plate is turned onto the door knob fitting and tightens up to a perfectly fitting assembly...but mine loosen up after some use.
Old 09-14-2010, 08:08 AM   #4
Ole Wood Worker
BigJim's Avatar
Rewards Points: 780
Go to the hardware store and get some "Loctite" and put a little on the threads. It may be a little tough to get the plate off when you need to change out the door hardware but it should stay in place until then with Loctite.
New members: Please consider adding your location to your profile.
If you do what you've always done, you'll get what you've always got.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is online now   Reply With Quote
The Following User Says Thank You to BigJim For This Useful Post:
oh'mike (09-14-2010)
Old 09-14-2010, 08:13 AM   #5
Rewards Points: 79
Check this DIY link
I found an old posting from this site. here is the link
How to Remove Gainsborough Doorknob?
It deals with removal of a knob problem on this brand - but reading post #7 of the thread speaks about the inner workings a bit. It seem as though the threads (female or male - or some of both) are stripped. Only thought there is to find something to either adhere, solder. or wrap to the male threading that will allow it to become tight enough to stay on. Of course, not doing any damage to the rosette if heating, as well as keeping any applied substance which would remain solid and allow the rosette to stay tight is the trick.
If you use that link, Check out thread 9 as it is a locksmith SN is genef.
Sorry i can't be of more help. But I am fairly certain you'll find someone with the right idea. Good Luck
Old 09-14-2010, 08:20 AM   #6
Rewards Points: 558
Use double sided tape behind the plate. Quick fix…
epson is offline   Reply With Quote
Old 09-14-2010, 08:29 AM   #7
Old School
Willie T's Avatar
I would suggest using Loctite #290 (the green stuff)... or perhaps use #22231.... but DO NOT use the red Loctite as you will likely never be able to get the faceplate back off without ruining it.
Willie T
Old 09-14-2010, 08:35 AM   #8
Ole Wood Worker
BigJim's Avatar
Rewards Points: 780
Thanks Willie, you are right on.
Jim
Drywall - hole for outlet bigger than faceplate slinku2020 Drywall & Plaster 6 06-30-2008 01:10 PM
Welding / faceplate modification question (see pics!) joeyboy General DIY Discussions 17 09-23-2007 05:54 PM
