-   -   Door install please help! (http://www.diychatroom.com/f19/door-install-please-help-4024/)
The RyeGuy 09-22-2006 11:17 AM
I just had homedepot ( whoever they contract out to) to install an exterior door...I think they scewed up the sill size....The jam in my door is 5 1/4inch...the sill is 13 7/16 (or something close)...ANyways, the sill sticks out about an inch and a half past the brick mold and is unsupported underneath..When you step on that portion of the sill, you can feel the back lift up.....I assume this is not normal but I haven't really paid attention to door sills before....I would think the sill should be relatively flush with the brick mold....Am I crazy????
K2eoj 09-22-2006 11:32 AM
Can it be supported with a 2x trimboard under the sill?? That would be correct. Sounds like that door may have been a special order for going to a deck with no stepdown. Nothing should be flapping in the breeze.
redline 09-23-2006 07:02 PM
needs more support or replaced with the proper size.
fhivinylwindows 09-23-2006 09:55 PM
They installed a 6.5" sill extension instead of a 5.25" extension. It will look bad if you support it and will create a hazard if you do not support it. Have the HD correct it, they can order the correct extension.
