Door Hinge For Tight Spaces? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 04-16-2010, 02:02 PM   #1
Just call me Andrew
Rewards Points: 1,020
Door hinge for tight spaces?
See attached drawing. Turns out that in the design for my bathroom, the door may hit the side of the vanity. It's a 24" solid pine door. I assume I cannot go smaller? Is there any type of specialty hinge that would prevent the door from swinging so far into the room? Thanks.
Andrew
secutanudu is offline   Reply With Quote
Old 04-16-2010, 02:35 PM   #2
Old School
Willie T's Avatar
Help us out. By how much will it hit? And exactly where?
And why is the commode off-center of the space it occupies?
Willie T
Old 04-16-2010, 02:37 PM   #3
gmhammes's Avatar
are you looking for something as simple as this?
http://www.lowes.com/pd_308834-54546...e|0$identifier=
gmhammes is offline   Reply With Quote
Old 04-16-2010, 02:43 PM   #4
Just call me Andrew
Some more details. The door that the wall is on is actually 2" too close to the vanity. My original plan was to move that wall back 2" so the door would have clearance to open all the way. On second thought, I'd rather not move that wall because the hallway behind it is tight as it is. I have about 23" between the door wall and the vanity if I don't move the wall.
My other option is to swing the door out, which would be odd but I could live with it.
The toilet will be in the center of that space, forgot to fix that in the diagram.
Andrew
Old 04-16-2010, 02:47 PM   #5
Tool Geek
PaliBob's Avatar
Rewards Points: 2,160
There is, so far as I know, no rule that says a bathroom door has to open IN.
Many exterior doors in Europe open OUT
I have seen home Exterior doors in the US open OUT
Why not have your bathroom door open OUT
Disclaimer
& Stay Safe
.....Bob Lavery
Old 04-16-2010, 02:49 PM   #6
fabrk8r
fabrk8r's Avatar
Does the wall in the hallway extend far enough West (to the left in your drawing) that you could install a pocket door?
You would need about 28" in order to have room for a 24" door, a couple studs at the end of the pocket and the rubber bumper.
Just a suggestion.
"The physician can bury his mistakes, but the architect can only advise his clients to plant vines." -- Frank Lloyd Wright
fabrk8r is offline   Reply With Quote
Old 04-16-2010, 02:49 PM   #7
Just call me Andrew
That is the most likely solution. I'd just prefer it to open in if I can.
Andrew
Old 04-16-2010, 02:50 PM   #8
Old School
Willie T's Avatar
Or something like these mounted either on the floor or on the side of the vanity?
Willie T
Old 04-16-2010, 02:53 PM   #9
Old School
Willie T's Avatar
What is next door? Where the 5'- 3/4" dimension is? Can you do a pocket door there? I've have a 24" pocket door for years now, and love it.
Might want to consider putting the light switch in the position closest to the door, rather than the floor heater control.
Willie T
Old 04-16-2010, 03:05 PM   #10
Just call me Andrew
Nope The wall ends right there, the door is on a corner.
Andrew
Old 04-16-2010, 03:11 PM   #11
Old School
Willie T's Avatar
You do realize that the wall does not have to be a full 4-1/2" thick? Most mobile homes have very thin walls... and this is not a large wall that it would be noticed much.
Willie T
Old 04-16-2010, 03:14 PM   #12
Just call me Andrew
That's a good point. It's not a load bearing wall. How thin can a wall be?
Is there any code requirement that says a door has to be able to open a full 90 degrees?
Andrew
Old 04-16-2010, 03:18 PM   #13
Old School
Willie T's Avatar
As thin as it will remain structurally sound. (Means: use good, solid material.) You'd be surprised how much extra hinges on a door will stiffen up that part of the wall.
Check locally, of course, but there are seldom many codes on interior doors, if any.
Willie T
Old 04-16-2010, 03:58 PM   #14
I believe the general rule for doors to open IN to a room is so that you can avoid accidently openning the door on someone who might be passing by. When you open a door IN, you can easily see what is behind you. But when you open a door out, you can't see what is on the other side.
Rather than changing the door, what if you changed the vanity?
I assume that based on your problem and room dimensions, the current plan calls for a 36" vanity. But I believe they come in 6" increments, and therefore you should be able to get a 30" vanity, allow the door to open ALL the way, and still have a few inches to spare. Another option would be a pedestal sink, but of course you loose some storage space. But you could always add storage over the toilet if you didn't already have plans for that.
HooKooDooKu is offline   Reply With Quote
Old 04-16-2010, 07:50 PM   #15
Just call me Andrew
I already bought the sink and vanity, and they are not returnable. I would much prefer the door opening out than losing storage. The bottom-right corner of the shower used to be a closet, so that space has already been lost. I may add storage over the toilet, i decided i'd do that if and when I need the room.
Andrew
HVAC for small spaces stubits HVAC 1 02-10-2010 03:26 PM
Fishing replacement wires thru inaccessible spaces tomseeley Electrical 5 11-12-2009 10:03 AM
Sealing Very small spaces before Insulation? Sheila4467 General DIY Discussions 3 11-11-2009 08:30 AM
Can foam sealer be used to seal the spaces in concrete block? marksto Building & Construction 6 04-21-2008 08:48 AM
Why are crawl spaces vented? AllGoNoShow Building & Construction 7 11-09-2006 05:33 PM
