Door Hinge Pin Worn? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 03-10-2013, 10:36 PM   #1
Rewards Points: 97
Door hinge pin worn?
I have a door that seems to sag. The door closes by itself. I've tried to tighten the screws of the hinge to the door but the door still sags. I lift the door and can see the hinge on the screw isn't moving but the hinge is moving where the pin slips through. Is it possible for the pin to be worn ?
edta1 is offline   Reply With Quote
Old 03-10-2013, 10:44 PM   #2
Rewards Points: 14,300
Sure it, try this simple trick. Pull the pin and set it between two blocks of wood and give it a wack in the middle a hammer to bend it slightly.
Still not working remove the hindg and buy a new one. Take the old one with you.
They come in differant widths, radis, and square, easyer to match up if you have it with you.
Old 03-11-2013, 11:02 AM   #3
doors that close on their own are usually not installed plumb and that is why they close or open on their own. bending the hinge pin can help for a while.
Old 03-11-2013, 11:22 AM   #4
Rewards Points: 6,652
How old is the structure, has it always done this? If the building has not shifted any, most likely the door was not hung true, if it has always done this, or if started recently, weight of the door is pulling down, and causing it to move.
painting worn brick pavers KathrynM Painting 5 06-21-2012 06:33 PM
Hose bibb: worn out screw autorun Plumbing 23 02-16-2012 09:36 PM
worn out drill bits or chuck? amakarevic Tools 13 02-05-2012 06:10 PM
Tape worn cable timcsi Electrical 3 12-22-2009 07:25 AM
REMOVE worn out STEM TYPE shower faucet... Wafot Plumbing 1 07-04-2009 07:58 PM
