Door Headers On Non-loadbearing Walls? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 09-21-2010, 09:41 AM   #1
the Musigician
DangerMouse's Avatar
Door headers on non-loadbearing walls?
Do interior walls (non-loadbearing) require door headers?
Or do I just frame with 2x4?
Thanks!
DM
Old 09-21-2010, 10:01 AM   #2
kwikfishron's Avatar
Rewards Points: 92
Just a 2x4 box header. Something to nail your sheetrock and trim to.
kwikfishron is online now   Reply With Quote
The Following User Says Thank You to kwikfishron For This Useful Post:
DangerMouse (09-21-2010)
Old 09-21-2010, 11:22 AM   #3
the Musigician
That's what I needed to know, Thanks Ron!
DM
Old 09-21-2010, 11:59 AM   #4
Ole Wood Worker
BigJim's Avatar
Rewards Points: 118
I totally agree that 2X4s is all that is needed but the inspector wouldn't pass that when I was building. There was a lot of things I didn't agree with the inspector either and that was one of them.
New members: Please consider adding your location to your profile.
He is no fool who gives what he cannot keep, to gain what he cannot lose.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is online now   Reply With Quote
Old 09-21-2010, 01:27 PM   #5
the Musigician
INTERIOR walls? Over the bathroom doors??? really..... huh.
I guess I need to know CODE on it then, just to be sure. Can anyone quote it?
Thanks!
DM
Old 09-21-2010, 02:12 PM   #6
Registered User
Rewards Points: 4,924
Not the 2006 or 2009, but google the code number of this 2003:
http://resourcecenter.pnl.gov/cocoon...er/article/125
Gary
The Following User Says Thank You to Gary in WA For This Useful Post:
Old 09-21-2010, 02:40 PM   #7
the Musigician
IRC 2000 and 2003, Section R602.7.2
Nonbearing walls. Load-bearing headers are not required in interior or exterior nonbearing walls. A single, flat 2-inch-by-4-inch (51 mm by 102 mm) member may be used as a header in interior or exterior nonbearing walls for openings up to 8 feet (2438 mm) in width if the vertical distance to the parallel nailing surface above is not more than 24 inches (610 mm). For such nonbearing headers, no cripples or blocking is required above the header.
Thanks Gary, you're the best at finding these darn things!
If he says anything about it, I'll have this sucker MEMORIZED to recite to him! LOL
DM
The Following User Says Thank You to DangerMouse For This Useful Post:
BigJim (09-21-2010)
Old 09-21-2010, 04:39 PM   #8
Ole Wood Worker
BigJim's Avatar
Rewards Points: 118
Well I just told on myself as to how long it has been since I was building, 10 years ago.
Jim
Looking for a step by step for framing basement walls/2x4's wrong direction/stairs??? xray328 Remodeling 27 06-19-2011 09:50 PM
Insulating walls for heated garage Huskie Building & Construction 5 09-19-2009 01:54 PM
Installing Plumbing in 2Ē Wide Walls? Robert1_1 Plumbing 5 09-16-2009 09:43 AM
bowing walls - repair? elementx440 Building & Construction 26 03-04-2009 04:07 PM
Moisture on walls chrisr Building & Construction 1 01-20-2008 10:37 AM
