Door Frame Reinforcement? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 02-01-2010, 12:46 PM   #1
Insert catchy title here
AppleMac*Fit's Avatar
Question
Door frame reinforcement?
I installed a new front door and plan on putting in a new back door on my house. I don't live in a bad neighborhood, but it's no Mayberry either....
I can buy a Pella door with a metal doorframe for around $700. Ouch. But if that's what will help protect my wife when I'm gone - I'm all for it.
I also see these products on the internet that are metal reinforcments to the puny 5/8" thick or so pine door frames, such as the 'Strikemaster II'
Here's a picture of theirs: StrikemasterII Now from videos of stuff like this I know it works. Eventually a battering ram went through the metal door after many hits, but the frame was intact. A good product, but lots of $$$ for a piece of metal.
I know if when I install the door if there's a large gap between the door frame and the door I am better off installing a solid piece of wood (perhaps a 1" thick piece of wood) as opposed to lots of shims to fill the gap. Also, I need to use 3-3.5" screws for the stricker plates and for 1 screw per hinge.
Here's what I'm thinking:
To reinforce the frame, could I just go to the hardware store and buy a 1/4" x 4" x 6' piece of aluminum for both sides of the frame? Then would I just screw the metal into the wood frame in a dozen places? Do you think that would work?
Any other things I should consider?
Thanks for any assistance!
AppleMac*Fit is offline   Reply With Quote
Old 02-01-2010, 03:03 PM   #2
Mold!! Let's kill it!
Rewards Points: 2,012
Where exactly would this aluminum be installed?
Old 02-01-2010, 03:29 PM   #3
On the outside of the door frame, attached to the door frame with screws.
What I'm picturing would be like this:
Old 02-01-2010, 03:38 PM   #4
Registered User
Termite's Avatar
Reinforced jambs are required in some municipalities in my area. Here's one product that can be retrofitted to existing doors:
www.jambbrace.com
Good installation videos:
http://www.jambbrace.com/videos.html
The system does work very well. To do it right you need to take the casing off and re-install it afterwards, because otherwise the system is only as strong as how well fastened the door already is.
Old 02-01-2010, 03:42 PM   #5
Rewards Points: 348
I think you need to reinforce the strike plate on the door frame using screws long enough to reach the framing. Also use long screws on the hinges that reach the framing. A dead bolt will increase the security somewhat. Using spray foam around the door jam will make the entire unit more secure and give it a very solid feel. The problem with making a door "super secure" is almost every home has glass windows on the ground floor. In my experience these are easier to break than even a cheap poorly installed door. If it is a newer home with vinyl or aluminum siding a utility knife and less than 10 minutes will get you through most walls even if the windows are not convenient and the door is secure.
Rege
RegeSullivan is offline   Reply With Quote
Old 02-01-2010, 04:46 PM   #6
locks only keep out honest people
Old 02-01-2010, 05:48 PM   #7
www.jambbrace.com
That is exactly what I was thinking of with the metal. Those videos are good to see... lots of kicking, but no entry!
True, but the glass takes longer to get through & is dangerous (risking cuts & injury) for the person. My windows are in bad spots, too (sharp bushes in front of). The big thing is deterrence. Most crimes are crimes of opportunity... a couple kicks on the door and the person should go away.
Absolutely. The idea is not to make my house impenetrable. If I wanted that I would construct my house with 3-feet thick cinderblock walls, lead-lined with no windows, steel doors and a tungsten-carbide 6-inch thick roof… with polar bears in the front yard to watch out.
I'm just looking for better security for while I am away so that with one kick the door doesn't come flying open. If it does, my German Shepherd will take care of the intruder and the alarm company will be sending police. Also, for while my wife and I are asleep at night, if a person breaks in - they are a predator (looking to harm people), not a robber, and the extra time it will take them to get into the house (whether through a window or via repeated kicks at the door) allows me more time to prepare for their entry.
Tags
door frames , security
Structural reinforcement needed (ridge beam) Stillwerkin Building & Construction 5 12-16-2009 07:55 PM
bathtub reinforcement needed? tpagel Remodeling 6 12-16-2009 06:30 PM
question on carbon fiber/epoxy bsmt cmu wall reinforcement stadry Building & Construction 9 10-13-2009 02:57 AM
Do I need mesh reinforcement for a 2 1/2" mud bed? jayp Building & Construction 1 06-11-2008 11:44 AM
Lower Fence Reinforcement (Need Ideas/See Pics) bswain06 General DIY Discussions 1 05-18-2008 02:37 PM
