Door Casing Issues - Building & Construction - DIY Chatroom Home Improvement Forum
Old 08-29-2007, 03:34 PM   #1
Door Casing Issues
Hello everyone. I am trying to put casing up around prehung doors that I just installed. However, my inexperience is showing through at this point. Apparently the door frame (jamb?) isn't quite flush with the drywall. When I attempt to put the casing on, I am holding it so it is flush with the drywall. When doing that, the casing is about 1/4 inch away from the jamb. Obviously then, if I try to make it touch the jamb, it pulls the other edge of the casing away from the drywall. I realize this may sound confusing when written in text only. If you need clarification or possibly even pictures, let me know.
Short of trying to remove the entire door and repositioning it, is there a fix for this? Thanks for any suggestions!
leted_82 is offline   Reply With Quote
Old 08-29-2007, 07:31 PM   #2
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
Quick answer: You "could" install 1/4" furring strips (that can be purchased at any Home Improvement store to install in the 1/4" gap)....as long as the gap is consistently at a spacing of 1/4".
If the space is not at a consistant 1/4", You need to cut the nails and re-position & re-install the doors.
- Build Well -
Old 08-29-2007, 07:48 PM   #3
A lot of times you can beat the Sheetrock to get the Trim to lay flat ( STOP SHARING TRADE SECRETS!!!).......Wait never mind reset the door.
Make sure it is flush to one side or the other. Then use extension jambs if still necessary.
jiggyjack is offline   Reply With Quote
Old 08-29-2007, 07:55 PM   #4
This is an example of LARGE width extension jambs (3.5"). The extension jamb is the stained portion. The pre-hung frame (in the pic.) had not been stained yet, when the picture was taken.
- Build Well -
Old 08-30-2007, 05:26 AM   #5
Here is an example of a furring strip added to build out a door jamb. This one was about 3/8". Sorry for the poor picture quality. It was attached evenly around the door jamb at a 1/4" reveal (set back). 18g brad nailer used.
- Build Well -
Old 09-01-2007, 12:30 AM   #6
Thanks!
Thanks for all the tips. I ended up furring it out using what the lumber yard called "screen moulding". It was the same width as the jamb, and 1/4 inch thick. Thanks again!
Mole Issues mattflytx Pest Control 24 06-06-2009 10:37 PM
Electrical issues with home inspection toolmaan Electrical 20 08-10-2007 05:52 PM
Issues with appliance plug hgiljr Electrical 1 03-17-2007 07:09 AM
Grounding Issues in a 1849 House Contractor's_Daughter Electrical 6 11-20-2006 10:56 AM
