Door At Bottom Of Staircase - Building & Construction - DIY Chatroom Home Improvement Forum
Old 04-21-2009, 02:42 PM   #1
Rewards Points: 18
Door at bottom of staircase
I have a finished basement, but the staircase down is wide open from the front foyer (townhouse). I was thinking of framing and installing an interior door (with small windows) at the bottom of the stairs so that light would still get in the basement, but I could be down there with my little one and not worry about her trying to climb the stairs. Any ideas on codes I should know about before I start? Any advice?
archiero is offline   Reply With Quote
Old 04-21-2009, 02:59 PM   #2
Drywall contractor
Rewards Points: 1,070
Why not a child gate until she gets bigger?? Don't know of any code that would affect what you put in....
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
Old 04-21-2009, 06:00 PM   #3
Rewards Points: 18
thought about just doing that, but also thought of the door as a sound barrier as well so that having someone in the basement working out to music won't disturb the person upstairs watching tv and vice versa.
Old 04-21-2009, 07:24 PM   #4
As long as you have a 3' landing you should be good
Door min height I think is 6' 8" ?
Old 04-21-2009, 10:16 PM   #5
Registered User
Rewards Points: 526
Egress: A second means of egress to the exterior is needed for each bedroom and for basements with habitable space. Doors: required exit is 3' wide x 6'8" high (side-hinged) door (1005.3.2.1 UBC)
Landings: landing required at top and bottom of stairs EXC door at interior stair may open away from top step (1003.3.5 and 1003.3.1.6X UBC)
Landing minimum 36" deep X width of door or stair (1003.3.3.5 UBC) Be safe, GBAR
Tags
basement , door , stairs
Bottom plates are not pressure treated Richo Building & Construction 10 03-16-2009 05:48 PM
Converting an open staircase to a "closed" staircase? tony1853 Building & Construction 7 01-05-2009 01:55 PM
Toilet: water still coming from BOTTOM of Inlet Valve DIY Mom Plumbing 1 08-12-2008 12:43 PM
Staircase help. audman Remodeling 6 09-07-2007 07:49 PM
