Old 10-12-2012, 06:32 AM   #1
door at bottom of bulkhead stairs
To help prevent heat loss in winter and keep humidity out in summer, I plan to build an insulated door at the bottom of poured concrete bulkhead stairs. I'm not terribly experienced with construction (I'm a hobbyist furniture maker), and would love any input in creating a good design, and installation method.
Thanks!
mpinjp is offline   Reply With Quote
Old 10-12-2012, 08:52 AM   #2
Not sure how anyone's going to be able to come up with suggestions without a picture of where you plan on putting the door.
Why would you "make" a door. most often you just build a wall with a pressure treated bottom plate and install an extrerier prehung door.
Old 10-13-2012, 09:58 AM   #3
OK here's a pic.
I was hoping to minimize the loss of width, and to avoid having a threshold at the bottom of the stairs.
Old 10-13-2012, 10:02 AM   #4
I'd suggest buildng three walls, one on each side and one for the door to be framed into. That would give you what would amount to a landing at the bottom of the steps.
Pressure treated bottom plates, insulate the walls.
The Following 2 Users Say Thank You to joecaption For This Useful Post:
mae-ling (10-13-2012), mpinjp (10-17-2012)
Old 10-13-2012, 11:08 PM   #5
I like to put 2" of sturofoam in the bottom of the stud bays. This way insulation can not wick up moisture, if there happens to be any.
Seal the studs to the concrete, and the poly as well. I Use acoustical sealant.
mae-ling is offline   Reply With Quote
The Following User Says Thank You to mae-ling For This Useful Post:
mpinjp (10-17-2012)
Tags
basement, door, plywood
my stairs Judi K. Carpentry 17 09-04-2012 03:06 PM
Tapering stairs at bottom to save space? BeanAcres Building & Construction 8 08-01-2012 01:25 PM
Staining & finishing pine stairs secutanudu Painting 33 10-23-2011 09:15 AM
Outside basement stairs, bulkhead stairs, etc anesthes Building & Construction 0 03-29-2011 06:33 AM
Transition of Hardwood Flooring on Stairs rkirby Flooring 1 02-02-2011 07:06 PM
