-   -   doing up a basment (http://www.diychatroom.com/f19/doing-up-basment-19537/)
littleparr 04-06-2008 08:08 AM
doing up a basment
Hi all...I'm new to the forum. My wife and I just bought a new home and I'd like to put walls, flooring and drywall in the basement, which is concrete. So, a few questions:
1. I am assuming I frame out and put up the walls before the subfloor.
2. How do I frame out and put up the stud walls, and how do I attach them to the concrete floor?
3. What is a good plan for installing sub-floors?
I guess you could say I'm new to home renovations, too!
chpwaman 04-06-2008 10:08 AM
I think if you do a few searches on this site, as well google some of your questions you will get very specific advice, which will help tremendously. I might also suggest that if you have never done this before, spend the $15 and buy a basement refinishing book from HD or Lowes or someplace similar...it will be a great resource for you.
AtlanticWBConst. 04-06-2008 01:32 PM
I suggest the same: Look into a book about remodeling basements. Illustrations help alot.
As far as the sub flooring. I prefer to install subfloors and subfloors systems after the walls are up, because I prefer to anchor the walls diractly to the concrete floor.
Here is an old Post from a while ago:
Hi,
#1.) It is best to have a 2" air space between concrete and the newly framed perimeter walls.
#2.) Framing: You could actually use 2x3's since the insulation is already there, but, as a 'newbie', I would advise using all 2x4's. You will want to use pressure treated 2’x4's for the bottom plates (PT on anything that you will attach to concrete). If you feel comfortable with such a tool: Use a 'powder actuated 22 caliber fastening gun'. Use coated 2 “ nails or longer (ceramic ‘coated’ nails have a grey color to them. You need coated nails because the current pressure treated process used for wood contains heavy amounts of copper. This reacts with regular ’bright’ nails and causes rust)
Use regular KD grade 2x4 Lumber for the top plates and the studs. Placed 16" OC (On Center). Make sure that you pick out nice, straight pieces.
You can use screws to attach your framing members, if you are unsure of using/renting a nail gun. If you use screws, get at least 2 “ or longer. I suggest using DECK screws (also for the areas where you attach studs to the bottom PT plate for the same reason as stated above) That length is sufficient, since you are not supporting anything structurally. You are just building ‘partitions’
#3.) Do a layout of your basement on paper with the actual measurements of what you want to do with your basement area in relation to walls, closets, rooms, etc.
#4.) Use this layout to determine the amount of lumber and other materials you will need.
Remember tot get long straight lengths for you top and bottom plates (12’ - 16’)
#5.) How to build your walls is determined on the age of your home. You see, if you have an older home, then the heights between your concrete floor and your floor joists will be inconsistent. Additionally, there really are no basement poured concrete floors that are truly level all the way through.
To pre build walls and stand them up and have them fit right, in addition to knowing where to install ‘corners’, corner nailers, etc….is really not in the newbie skill level.
So, I would suggest you just go by the ‘stick-framing’ method. What this is can be found in #7.)
#6.) Note: if you have to build any doorways, it is unnecessary to install actual ‘headers’ on top of the doors, since these are only partition walls. Your house is already built with all the headers and supports that are supposed to be in it. I see this waste of time and lumber a lot in DIY-er basements.
#7.) To stick frame your walls: If you are going to put a Sheetrock ceiling in, then it is best to start at your ceiling first and install strapping every 16” OC. This will also give you something to attach any walls you build that run parallel to your floor joists.
After you do that, or even if you plan on installing a ‘dropped ceiling’:
Start Walls:
Layout your walls on your floors first by cutting and laying your PT 2x4’s to the floor. Mark where your studs will go FIRST. Then fasten your bottom plate to the concrete floor. Fire-in your concrete fasteners between each stud. That way, if a nail does not go in all the way, it will not effect your stud placement. (You can also use concrete expandable fasteners for this, like “Red Heads“. Tho this takes A LOT more time)
Marking out the studs for the top plate:
Take, a KD piece of lumber that you will use to make the top plate that will match that bottom plate and place it along side of the now installed PT bottom plate.
Transfer the marked stud lines onto the top plate using a speed square (triangle). Much quicker and accurate this way. It’s how we frame entire houses.
How to level the bottom and top of walls:
Cut a STRAIGHT piece of 2x4 to just over the length of your floor to ceiling height. You will use this as a straight edge to place your level against to mark up where your top plate will be on the ceiling. Just hold the straight 2x4 against one side of the bottom plate. Place a 4’ level or longer level’ against it. (we prefer to use a 6’ level for this) Then line it up to the ceiling and make a mark on the joist or strapping for the matching edge of your top plate.
Do this at one end, of the length of the bottom plate. And then at the other end of the bottom plate. Laying out this way for each wall.
Studs:
Take the measurement for each of your studs. Cut them exact, to a 16th of an inch to get the stud to fit tight, but not so tight that it bends or bows. If you shortcut a stud, you can shove a shim into the space to tighten it. (Side point- every piece of lumber has what is called a ‘crown‘. A crown is a slight ‘hump‘. Try to make all the crowns of your studs face one way…usually towards the inside of a room. This way, your walls aren’t wavy)
As your go along, you can check your walls and studs periodically for alignment using your levels, framing square, eyeball, tape measure and even a string stretched tight to make sure a wall is straight.
GOOD LUCK!
AtlanticWBConst. 04-06-2008 01:48 PM
There really is alot that can be said regarding all the aspects of remodeling/finishing off a basement. As stated, you could do a search on this site for such.
Here are some basement framing pictures that may help you too:
http://i28.photobucket.com/albums/c2...s040904070.jpg
http://i28.photobucket.com/albums/c2...s040904069.jpg
http://i28.photobucket.com/albums/c2...s040904073.jpg
http://i28.photobucket.com/albums/c2...s040904099.jpg
littleparr 04-06-2008 02:56 PM
wow, thanks so much...our basement has concrete in the bottom half and studs and fibreglass in the top half of the wall. (I like the last pic, think I would do it that way). It's a brand new house, just constructed.
How long should you let the concrete dry before attempting the basement/subfloor reno? The concrete basement has been in existence for 1 year. Also, what about plastic and do you need to lay it anywhere?
raam 04-06-2008 09:10 PM
No need to wait. They should have placed a plastic vapor barrier under the floor slab already.
AtlanticWBConst. 04-07-2008 08:10 AM
Personally, I like Dricore in basements.
http://www.dricore.com/en/eIndex.aspx
littleparr 04-08-2008 08:28 PM
So where would have this plastic vapor barrier gone, you mean on top of the ground before they poured the concrete?
