Old 08-30-2009, 07:38 PM   #1
Does Structural Lumber Warp?
Does moisture loss and shrinkage affect the structural integrity of a building? I'm talking on a small scale, say a shed 8'x12' and most likely using Douglas Fir. Is moisture content a consideration when building this size of a structure? Thank you.
applebuilder is offline   Reply With Quote
Old 08-30-2009, 09:24 PM   #2
Moderator
Termite's Avatar
High moisture content (wet use applications) plays a role in lumber's strength, but not in this case. Yes, structurally graded lumber will absolutely warp/twist/shrink/check. When selecting lumber it is best to look for KD Doug fir lumber that has been kiln-dried to a moisture content of 19% or less. That'll help it remain dimensionally stable. Honestly, the "green" undried stuff will work fine for building a shed. Doug fir is pretty stable in general compared to pine lumber, especially southern pine.
For an 8x12 shed the structural considerations are pretty minimal.
Old 08-30-2009, 09:33 PM   #3
Old School
Willie T's Avatar
I'm with KCT. Stay the heck away from SYP PT if you want to have any hope of your lumber remaining straight.
Willie T
Old 08-30-2009, 10:16 PM   #4
Thanks for the advice, good thing all we have around here is doug fir, no southern yellow pine to be found.
Brick veneer or Structural Brick? nimblemotors Building & Construction 19 02-22-2013 09:11 PM
Dry lumber from HomeDepot HandyPete General Discussion 17 03-25-2011 01:50 PM
Raised garden bed using PT lumber rjniles Landscaping & Lawn Care 12 06-24-2008 10:14 PM
Concrete steps and stucco cracked-Is this structural problem? yummy mummy Building & Construction 17 04-14-2008 10:24 AM
Framing lumber very hard?? handyflyer Remodeling 2 04-15-2007 11:44 PM
