Does A Sill Need To Be PT? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 08-31-2008, 07:35 AM   #1
I have gas!
Clutchcargo's Avatar
Rewards Points: 1,362
Does a sill need to be PT?
I'm tore down a sunroom to get to the top side of an open cell cinder block foundation so that I can fill the the open cells. The 80 year old 4x8 sill is in perfect condition. Is there a code that says this must be PT or can I recycle the existing sill?
I tear things down and build them up.
Clutchcargo is offline   Reply With Quote
Old 08-31-2008, 09:08 AM   #2
BUILDER / REMODELING CONT
buletbob's Avatar
is there a permit for the job? At least install a termite shield.
Old 08-31-2008, 10:45 AM   #3
Registered User
Termite's Avatar
The money savings of recycling the original won't offset the potential for future damage. I'd suggest putting a treated sill plate back in. That could be ACQ, Wolmanized, or Borate treated.
And yes, the code requires any concrete/masonry contact wood to be pressure treated.
Old 08-31-2008, 06:10 PM   #4
I have gas!
Yes permitted, I pull permits on all my projects.
Your probably right with the PT, but I was thinking if it made it 80 years and it's still in great shape with concrete contact, why not extend it's life. When I rebuild, it wouldn't be in direct contact, there would be a layer of that thin pink foam between the sill and foundation.
I spent my day tearing down the old sunroom and I'm down to the floor. Maybe when I get a closer look at the sill, it might be a different story.
Old 08-31-2008, 06:51 PM   #5
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
Originally Posted by Clutchcargo View Post
...When I rebuild, it wouldn't be in direct contact, there would be a layer of that thin pink foam between the sill and foundation....
You are referring to "sill-foam".
Sill foam is used as a means to limit air-infiltration (insulation). It is not a true moisture barrier, or recognized as a material the will inhibit the wood from rotting. You still are required by code to use P.T. as a mud sill plate.
Sill foam: http://www.dow.com/styrofoam/lowes/p...s/sillseal.htm
- Build Well -
Old 08-31-2008, 08:22 PM   #6
Registered User
Termite's Avatar
x2!!!
Here, we call it sillsealer.
Old 09-01-2008, 07:39 AM   #7
I have gas!
Thanks guys, I won't salvage the sill plate for this application. I'll use it someplace else.
Replacing Rotten Sill Plate Material Tester Carpentry 6 03-28-2011 08:08 PM
Replace door sill = Need new door? NNJGUY Carpentry 23 09-01-2009 01:54 PM
Door Sill Flashing Pondo13 Building & Construction 1 08-19-2009 06:15 AM
replacing rotted sill plate and rim joist behind a deck ledger board tommyt Building & Construction 2 08-11-2008 07:38 PM
repairing rotted sill dwlodyka Building & Construction 4 02-27-2008 07:38 AM
