Does Rigid, Thin R30 Insulation Exist? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 06-13-2010, 01:02 AM   #1
kai
Does rigid, thin R30 insulation exist?
Hello there. I am exposing the beams in my bedroom. I was assured that insulating it with R30 rigid thin insulation would be no problem. My contractor says no such thing exists. Can anybody tell me where to get it if it exists? Thanks, Kai
kai is offline   Reply With Quote
Old 06-13-2010, 01:41 AM   #2
kai
I am not sure how to amend my posting, but I need to. Sorry, I should have researched before posting, but I thought the contractor must be correct or in the alternative, it would be very hard to find. It was not hard to find. Here is one site for rigid r 30 insulation, among others http://www.truittandwhite.com/produc...seaction=other. Thanks all. Kai
Old 06-13-2010, 01:45 AM   #3
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
what is "thin".
One of the best and readily available insulations is polyisocyanurate foam boards but even that is around R7 per inch per inch. It would take a bit over 4 inches to give you an R30.
yep, per your link: a 4 1/2 inch thick board with an R30.
Might want to check on the price of that stuff, Not going to be cheap
How To Install Rigid Foam Insulation on Concrete earthad1 Building & Construction 9 10-26-2010 10:49 AM
Rigid Insulation on the interior walls during remodel KHM Building & Construction 2 04-29-2009 10:08 PM
super insulation retrofit with rigid insulation hostaking Building & Construction 5 01-07-2009 11:23 AM
Using rigid foil faced foam insulation Ronnie1a Remodeling 1 01-22-2008 02:23 PM
Rigid insulation question Endeavor General DIY Discussions 2 07-17-2007 11:27 AM
