Does A Ridge Vent Have To Span The Entire Ridge? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 01-11-2011, 09:53 AM   #1
Does a ridge vent have to span the entire ridge?
I only ordered enough ridgevent for the house. I forgot to include the garage. If I take a 4' from each end, I'll have enough. Is this acceptable?
EC1970 is offline   Reply With Quote
Old 01-11-2011, 11:26 AM   #2
my house has it from end to end....while my neighbors house does not (its set back about 5 feet from each end.) dont know if one way is more right than the other, just have seen it both ways.
I suspect the right answer includes some calculations regarding air flow.
1910NE is offline   Reply With Quote
The Following User Says Thank You to 1910NE For This Useful Post:
EC1970 (01-11-2011)
Old 01-11-2011, 11:50 AM   #3
BIGRED
Rewards Points: 252
Yes it is perfectly acceptable. Most roofers will hold the ridge vent back from the ends of the ridge just so the roof is easier to seal at the ends. I have a hip roof on one end of my home and a straight gable end on the other. The gable end actually has a 2-4 foot soffit that I thought should be vented as well, though the roofers say it isn't needed since there is no heat and humidity built up in the overhanging soffit. I did it anyway just to maintain a somewhat symmetrical appearance on the roof.
Grampa Bud is offline   Reply With Quote
The Following User Says Thank You to Grampa Bud For This Useful Post:
EC1970 (01-11-2011)
ridge vent termination at roof apex? morbegno Roofing/Siding 1 01-15-2010 08:37 AM
ridge vent w/ roof louvres? byocum Roofing/Siding 3 08-31-2009 06:17 PM
best ridge vent? ponch37300 Roofing/Siding 4 07-23-2008 08:00 PM
Ridge Vent > Gable Vent jelly Roofing/Siding 10 06-09-2008 07:30 AM
attic ventilation design help Noreaster Roofing/Siding 15 04-30-2008 08:31 PM
