Does This Need Fireblocking - Building & Construction - DIY Chatroom Home Improvement Forum
Old 02-28-2014, 01:53 PM   #1
Rewards Points: 85
does this need fireblocking
attached is a photograph of where my soffitt and ceiling come together. I removed a piece of drywall for a better view. Does the area above the top plate of the soffitt, up to the bottom of the floor and between the floor joists need fireblocking? If so I have Roxul that I can stack above the top plate of the soffit, or I can cut some 5/8 drywall and fill in the spaces with that in areas where there are no obstructions?
boilermaker27 is offline   Reply With Quote
Old 02-28-2014, 04:45 PM   #2
Rewards Points: 256
Were the wall meets the soffit it needs fireblocking. In the middle of the ceiling it doesnt.
JustinK is offline   Reply With Quote
The Following User Says Thank You to JustinK For This Useful Post:
boilermaker27 (02-28-2014)
Old 02-28-2014, 07:58 PM   #3
Registered User
Rewards Points: 4,902
#12; How to fireblock framing
Where per code; http://publicecodes.cyberregs.com/ic...002_par017.htm
Over 1k sq.ft.--- then in the floor above; http://publicecodes.cyberregs.com/ic...2_3_par078.htm
Gary
Old 03-26-2014, 06:51 PM   #4
Rewards Points: 20
Basically you want to close off any opening from the vertical wall space from the space leading into the floor joist so a fire can not go there.
dnwong is offline   Reply With Quote
Seeking recommendations for fireblocking mklein49 Building & Construction 5 02-23-2014 04:28 AM
Fireblocking top of rigid foam board? ndmeier Insulation 1 02-01-2012 09:27 PM
Basement Fireblocking within HVAC Soffit ssmith147 Building & Construction 3 12-31-2009 07:36 AM
Fireblocking ? BrianAg95 Building & Construction 7 10-06-2009 09:56 PM
fireblocking basement phospher Building & Construction 5 03-14-2009 02:07 AM
